Old 10-04-2004, 12:14 PM   #1
68on22s
68 in progress
new style motor mounts?
someone else probably asked this but do new motor mounts fit on our trucks. I have a 68 frame and 74 crossmember so can I put the newer style mounts on.
68on22s is offline   Reply With Quote
Old 10-04-2004, 02:39 PM   #2
roj2323
i tryed a set off of an 85 suburban. they fit but only sort of. i need to measure the distances between the top holes and between the bottom holes with them mounted on the 85 frame then mount them to the 67-72 frame using the numbers. even then you may want to slap an engine and tranny together and set it in the frame to make sure the engine is set at reasonable angle.
ondrew
p.s. please let me know if you come up with a solution.
thanks,
ondrew
roj2323 is offline   Reply With Quote
Old 10-04-2004, 06:22 PM   #3
onetoncrewcab
One of my kids. Cute eh?
onetoncrewcab's Avatar
I am in the middle of this swap. I have a 70 Chev with a 1980 cradle. From what I remember, the frame on the 70 is a 1/2" shorter in height than the 1980. I'll need to put a spacer between the mount and frame to get things evened out.
I'm in school again and I probably won't get back to the project until next summer.
Mike
If a kid asks where rain comes from, I think a cute thing to tell him is “God is crying.” And if he asks why God is crying, another cute thing to tell him is “Probably because of something you did.
John 3:16
2006 Chevy HHR
2000 Dodge Durango
1985 Jeep CJ-7
1970 Chevy Pickup
onetoncrewcab is offline   Reply With Quote
Old 10-04-2004, 09:16 PM   #4
1972C10
1972C10's Avatar
I put stands off an 81 onto a 68 I had It worked out great The top two holes were already there i had to drill the bottom holes into the crossmember.
1972C10 is offline   Reply With Quote
Old 10-04-2004, 11:16 PM   #5
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
i want to do this too...i have a 67 and a 87 parts truck.
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 10-04-2004, 11:18 PM   #6
1972C10
1972C10's Avatar
It worked out good for me I have seen some that had lugnuts as spacers I dont know if there are different hieghts or if whomever did the truck i seen used the bottom bolt holes and made new ones for the top.
I know one thing Its alot easier to get motor mounts in poly or solid config rather than a 67-72 type mount.
Old 11-03-2004, 09:24 PM   #7
roj2323
hey all,
well i'm bringing this old thread up hoping that someone can help me out here. i am currently doing this swap and i ran into a problem.
i mounted my brackets like 1972c10 did by bolting the frame brackets to the top rail and drilling the crossmember. this part went well and looks awsome but when i tried to test fit my sb350 and trans i found that the engine was sitting wayyy too high. the engine mounts are about 2 inches too high. i'm thinking that i need to change the brackets that are bolted to the engine to car mounts instead of trck mounts as they currently are. if you have done this swap and can tell me what you used i would really aprecheate it.
thanks,
ondrew
p.s. i am taking pictures so i can make an faq on this topic when i get done.
Old 11-03-2004, 11:37 PM   #8
1972C10
1972C10's Avatar
There is a difference between car clamshells and truck clamshells. I found that out the hard way after years of piling the clamshells up i used a pair found out they were different after that i write on them what they came off of.
Old 11-04-2004, 12:05 AM   #9
roj2323
sooo did you use car "clamshells"?
ondrew
Old 11-04-2004, 12:09 AM   #10
1972C10
1972C10's Avatar
No i used the clamshells off a the truck.
Old 11-04-2004, 12:10 AM   #11
1972C10
1972C10's Avatar
Are both your bolt holes lining up? Because mine woudlnt line up with the wrong clamshell on it.
Also there are two sets of boltholes that you can bolt the motor mount to. The stands i put in had the mounts on the bottom holes.
Old 11-04-2004, 12:20 AM   #12
roj2323
none of the holes are lining up. the engine is siting 2 inches 2 high. the top of the engine mounts are actuly allmost even with the top of the frame rails. this is with truck clamshells. the only thing i can possably think of is maybe it's a set of van clamshells but as far as i know they should be the same.
thanks for your help so far,
ondrew
Old 11-04-2004, 12:39 AM   #13
1972C10
1972C10's Avatar
Man ive got a pile of clamshells if you need any I have no idea as to what any came off but one pair I have a pair off a pontiac trans am. I think ...Ill do some lookin
Old 11-04-2004, 10:11 AM   #14
roj2323
thanks it would be aprecheated. even a part number off of one of the installed clamshells would suffice. i can take the number over to the chevy dealer and find out what it's off of.
thank you,
ondrew
Old 11-04-2004, 10:39 AM   #15
ale8oneboy
ale8oneboy's Avatar
Anyone had any trouble with motor mounts letting go? On 67' Chevelles they issued a recall because the factory motor mounts would break or crack. This caused the motor to fall, pinning the throttle. I believe this may have only been for smallblock (non-SS) cars.
MEMBER OF THE BUCKET SEAT CLUB (REAL BUCKETS)
"Color Me Gone" - Two Lanes of Blacktop
ale8oneboy is offline   Reply With Quote
Old 11-04-2004, 11:53 PM   #16
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
These trucks were recalled too. The 'fix' was a cable wrapped around the dvr's exhaust manifold, and down to the upper a-arm. Some dealers actually made brackets, but most of the ones I've seen were just looped around the manifold.
Old 11-05-2004, 10:00 AM   #17
ale8oneboy
ale8oneboy's Avatar
Yep. Pretty much the fix on the Chevelles too. My brother owns a 67 Chevelle and has had the mounts give on him before. Pretty scary. When we were working on my truck he noticed the mounts arn't much better for the trucks than the cars.
Old 11-05-2004, 03:55 PM   #18
crazy longhorn
Fabricate till you "puke"
The stock mounts were a big problem on these old trucks, as well as the mid 60's cars. the aftermarket replacement mounts arent bad tho.....I am on my 4th season with the mounts on my 383, & still going. That thing has had the clutch dumped @ 5000 rpms a few times, as well as hammering all those gears! I do plan an upgrade to urathane, but as long as what I have "works", I cant afford the replacement cost crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-06-2004, 01:44 AM   #19
1972C10
1972C10's Avatar
I Made some Solid Mounts to stop mine from flexing I never could find a source for Urethane or solid .. But then again this was 5 years ago . Whats Urethane Motor Mounts for a 67-72 Going for nowadays?
Thats one of the reason i converted that 68 of mine to later style mounts Plus being easier to line up the solid and poly mounts are cheaper than 67-72
Old 11-09-2004, 10:38 PM   #20
roj2323
well i got a set of mounts from gm today. i ordered a set for an 85 c10. unfortunently there the same as the set i have on the engine all ready so it's still a no go. 1972C10 please concider crawling under your truck with a flashlight and writing down the number stamped on the mount. i will pay you if nessasary. i am so confused and tired of playing ring around the rosie please help.
ondrew
Old 11-10-2004, 12:41 AM   #21
1972C10
1972C10's Avatar
Ill see if i cant get a P/N Althou they were Truck Clamshells. I thought you needed a P/N for Car Clamshells>?
Old 11-18-2004, 09:46 PM   #22
roj2323
well i think i finaly figured it out. the engine mount to frame brackets i was using were off an 85. today i finaly got to look at a 76 and an 85 next to each other and i noticed that the frame brackets are drasticly different. i personaly beleive that this was because of the exaust manafolds but anyway the [73-80?] brackets make the engine sit aprox 2in higher that the [80?-87] brackets do. this accounts for the 2 inches i was having a problem with and will hopefully fix the problem. i'll find out whan i get the brackets in the comming week. my only hope is i don't have to modify anything.
ondrew
Old 11-18-2004, 09:50 PM   #23
67ChevyC10Stepside
so i can take the ones off my 86 truck and they will work?
Old 11-18-2004, 09:54 PM   #24
roj2323
from what i have expeirenced no. this may be different if you use spacers on top of the frame between frame and the bracket but i haven't tryed it and personaly i think it would look tackie.
ondrew
Old 11-18-2004, 11:01 PM   #25
1972C10
1972C10's Avatar
Are you sure you dont have Big Block 73-87 mounts? There is a difference and big block towers would need the spacers
