Old 10-04-2004, 06:56 PM   #1
incoma
incoma's Avatar
Cargo Light mounting question
For all of you guys that had to re-mount the cargo light - How did you do it? I havne't had any luck finding a mounting nut like the original. I've found some well nuts and they aren't tightening up enough to hold the cargo light against the cab. I was going to try to use some normal nuts, but the light connector that fits inside the sheet metal won't let me get a wrench on it to tighten.. Please help me out with some thoughts...I'm getting frusterated.
incoma is offline   Reply With Quote
Old 10-04-2004, 07:04 PM   #2
john
member #16
john's Avatar
I bought some from LMC, they are a nut encapsuled in rubber. It wouldn't stay tight and I ended up with a nut inside on top of the other one and it stays tight now. Good luck John
john is offline   Reply With Quote
Old 10-04-2004, 07:08 PM   #3
incoma
incoma's Avatar
It sounds like they're selling the same well nuts that I'm trying to use... There's got to be a way to get these things to work..
Old 10-04-2004, 07:11 PM   #4
john
member #16
john's Avatar
I had a friend tighten them while I held them on the inside. There wasn't much room to get the nut in.John
Old 10-04-2004, 11:18 PM   #5
incoma
incoma's Avatar
I guess I'll try this next unless someone else has any other ideas. BTW, John, that is a beautiful truck. Great job on that interior, it looks great!
