Old 10-04-2004, 09:01 PM   #1
wHATANERD
wHATANERD's Avatar
Undercoat removal ???
I need some help, Next weekend I plan to starting stripping the bed down on the new 1970 longbed, and need to know the best way to remove the undercoating from the bottom side of the bed. Any suggestion would be greatly appreciated.
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
Old 10-04-2004, 09:05 PM   #2
Gee_Emm
Putty knife and a propane torch
Gee_Emm is offline   Reply With Quote
Old 10-04-2004, 09:35 PM   #3
botboy
If you go puttyknife and propane torch, get lots of paint thinner to take the undercoating grime off down to bare metal (I assume you are going to paint or reapply undercoat here)
My experience has been that a grinder & wire wheel is the best for removing undercoating down to bare metal. Make damn sure you wear safety glasses and really crappy clothes because it's guaranteed you'll have molten rubber and wires flying everywhere.
botboy is offline   Reply With Quote
Old 10-04-2004, 10:27 PM   #4
wHATANERD
wHATANERD's Avatar
I will be taking it down to the metal, It looks like I;m in for some serious fun. (NOT!), thanks for the responses
Old 10-04-2004, 11:04 PM   #5
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Have it sand blasted. That'll remove everything!
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 10-05-2004, 02:16 AM   #6
longhorn71
longhorn71's Avatar
sand blasting will warp it.knife and torch or baking soda blasting is the best
longhorn71 is offline   Reply With Quote
Old 10-05-2004, 05:46 AM   #7
cdowns
cdowns's Avatar
eastwood co has a product called"under off" for removing undercoating
Old 10-05-2004, 07:41 AM   #8
Joe67
67 is sold
Yet another reason not to undercoat
I agree with the putty knife method, painful but effective
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 10-05-2004, 08:04 AM   #9
glock35ipsc
Sure, if done incorrectly. Best done with walnut shells, and maybe a mix of glass.
Bob
Old 10-05-2004, 08:39 AM   #10
mocwon
Keep On Truckin'
mocwon's Avatar
Sand blasted my bed inside and underside with #4 blasting sand from a pressurized pot, no warping. Don't sand blast the inside of the fenders though or you could warp them.
Soda blasting will not remove rust.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 10-05-2004, 10:22 AM   #11
dallas71
dallas71's Avatar
I used paint stripper (aircraft paint stripper from autozone) made the undercoat real easy to remove...little messier but a whole lot less heat.....
dallas71 is offline   Reply With Quote
Old 10-05-2004, 11:19 AM   #12
Southpa
Southpa's Avatar
Everyone is assuming a steel deck, if so, then heat and putty knife. I wouldn't use any open flame tho, a hot air gun will do the trick. If its a wood deck then I would just leave it alone!
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 10-06-2004, 11:19 AM   #13
wHATANERD
wHATANERD's Avatar
Has anyone used the stripper from Eastwood?
Old 10-06-2004, 09:26 PM   #14
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Never used the stripper but I did use a stiff wire wheel on my makita disk grinder to remove all the undercoating off the botton of my truck..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
