2 tons of fun
I am still trying to figure out why my new power steering pump won't work correctly. I have tried jacking it up with the engine running and turning lock to lock for about 45 minutes but it still feels the same (Not smooth). If I turn the wheels lock to lock with the engine not running it sounds like there is air in the system. And also it will spit fluid out of the cap on the p.s pump when turning with engine off. Is this air forcing the fluid out or is it normal for this to happen just because the pump isn't turning? Thanks.........Lumpy
67 Chevy,Short/Fleet,350,Saginaw 4-Speed,Lowered 4x2,small window,P/S,Edelbrock Intake/Carb,HEI,Gear Drive,Crane Cam 274H Three Rivers, Ca Pics at: http://www.cardomain.com/id/lumpy454 |
"Ochre Ogre"
The spit up is from the trapped air. With the engine running the pump is pressurized and the bubbles are compressed, with it off they expand to their normal size and push fluid out the cap.
Some how you need to get that truck up on you shoulder and patt it on the hood until it burps. When I did my suburban it took about 30 minutes to clear the air bubbles. I also did it again the next day just to let the fluid settle down. When you are turning lock to lock are you doing it slowly? Sorry , don't really have any better advice than to keep trying.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
the assemby manual says that if you get air bubbles, let it set for 45 min. then bleed it off.
------------------ 71 basic C-10 350. The only option is the rust.No nothing on it, but thats all about to change. <A HREF="http://www.geocities.com/stevemau/slam33page.html?1004806705410 " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A>
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
2 tons of fun
Thanks for the replies guys. Slam when you say let it set for 45 minutes then bleed it off. Does that mean turn it lock to lock again? Thanks......Lumpy
![]() Join Date: Apr 2000
I think I remember reading that before you put the belt on to turn it counter clockwise by hand to get the air out.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
Guest
Posts: n/a
IF THERES A JIFFYLUBE NEAR YOU THAY HAVE
POWER STERRING FLUSH MACHINES,ITS A GOOD IDEA TO FLUSH OUT AFTER A PUMP REPLACEMENT OR BOX REPLACEMENT. I HAVE ONE AT THE SHOP AND ALWAYS USE IT IN A CASE LIKE THIS. WYNNS MAKES THE UNIT AND THE FLUSH KITS. ALSO THERE IS NOW AIR WHEN DONE. JUST A THOUGHT. GOOD LUCK" ------------------ 72BLUE C10 SWB 86BLUE K10 LWB 87RED S10 SWB 89RED S10 SWB |
