GO VOLS!
little by little...
got the drivers rocker box in, rear lower door pillar, fabricated the back half of the lower rear door pillar, fabricated the panel in between the back of the rocker box and door pillar, and have the inner rocker panel ready to go in after rust proofing the inside of the rocker box. Progress is good
http://1972blazer.shutterfly.com/<= blazer build pics It's called golf because all the other four letter words were taken. It's easier to ask for forgiveness than for permission. Last edited by orangeuavol; 10-04-2004 at 09:57 PM. |
Member since 2000
I'm actually looking forward to do the floor boards. Looks good man, keep up posted. I hope I can squeeze 1- 2 hours after work this week to finish the windshield.
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Damn you guy's are amking me leary(sp) about cutting into mine it seem's that everytime I got to fix something with the body it turn's into a big why the hell would the p.o. do that ????? HINT=(aluminum foil) bOTH YOU GUY'S ARE MAKING SOME VERY GOOD PROGRESS THOUGH KEEP UP THE GOOD WORK...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Do a step by step on the other side and post it in the FAQ section....
Good job...
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
Doesn't it drive you nuts when you buy "Goodmark" or other "quality replacement metal" only to find it is so far off from original that you wind up having to fab the !@#$ out of it to get it close. You would think that the importers would check the quality before selling this junk. I have yet to find an aftermarket lower door pillar, rocker, or cab corner that is close to factory original!!! ARG!!!!!!!!! Guess it is still better then aluminum foil and duct tape.
GO VOLS!
I'd do a step by step but I really don't know what the correct steps are. Its hard to know if its wrong if you never knew the correct way to start with
http://1972blazer.shutterfly.com/<= blazer build pics It's called golf because all the other four letter words were taken. It's easier to ask for forgiveness than for permission. |
