10-04-2004, 10:33 PM | #1 |
Ford 9 inch Disc Brakes F/S
I have a 9 inch rear with factory disc brakes for sale .It is out of the bic car line of Fords and has the 5 on 5 inch bolt pattern that is the same as Chevy trucks. It is complete .I do not know what gear and I am sure that it isnt a posi .I will let it go for $200 .I may be able to meet you to save on shipping. It is in Bryan,Tx. 979-272-9403 or frankm@tconline.net .My email has been slow lately. I do not want to ship this so I guess it is for Texas members or surrounding states. Frank
10-04-2004, 11:06 PM | #2 |
Garage Queen Material
i'm interested. whats the length of it?? how well will it fit under one of our trucks?
10-04-2004, 11:14 PM | #3 |
I have the same rearend in my 63. I ended up making some brackets and using 72 chevy front calipers because the ford calipers were about 100 a piece and a lifetime 72 caliper is 20 bucks, and it makes buying pads easier since the front are the same as the back.
Youth soon passes away, but immaturity can last a life time. |
10-09-2004, 05:53 PM | #4 |
any update?
10-09-2004, 07:27 PM | #5 |
I will get the pics to you tomorrow.I have been plenty busy at work lately and it seems that it is dark every night when I get home.Frank
10-11-2004, 11:02 AM | #6 |
How much to ship to Milwaukie Oregon 97222. Thanks
10-11-2004, 12:04 PM | #7 | |
it would cost a lot to ship i'm guessing |
10-11-2004, 10:28 PM | #8 |
I shipped two different 12 bolt car rears .One to Michigan and one to Minnesota.They were both over $200 to ship which would double the price. Oc ,did you get the PM yesterday. I am having trouble getting a picture. Camera and comp probs. It is a heavy 9 inch that is about 63.5 inches wide at the wheel mounting flanges. If I can get my act together OC is first in line I think. Frank
01-09-2005, 01:16 AM | #9 |
Rear
Still have this rear . $150 Anyone? I need to get it out of the way.Frank
01-14-2005, 01:17 AM | #10 |
any idea on the gear ratio? and do you know the width?
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
01-23-2005, 01:44 AM | #11 | |
We can roll all Day!!
If you know let me know. I am not worried about the perch distance but rather the wheel mounting surface to wheel mounting surface. |
01-23-2005, 01:47 AM | #12 |
Project92 SWB stepside
Why are all the good deals so far away??
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
01-23-2005, 04:33 PM | #13 |
To eliminate the issue w/the early disc hardware, would later model Ford explorer parts work to update the rear discs?
01-23-2005, 08:57 PM | #14 |
rear
I am sure it is a 2.xx gear non posi since it came out of a luxury car .It is dirty and has a lot of mounting brackets that it used for the car that would have to be removed but I have seen them under trucks before .I tried to measure the width and it looks like 63 1/2 " from flange to flange ( where the wheels bolt on ). I dont have a truck rear to compare it to right now .Anyone know what the width of a Chevy truck rear is ? Please post it . Frank
01-24-2005, 01:48 AM | #15 |
I am intrested if your other buyer backs out. I just need to verify the length of my current axle and make sure I can get the proper offset in the wheels I want.
Can you tell me the distance in between the axle tube flanges, so I can make sure I can weld in my spring perches and make it work. |
03-21-2005, 10:54 PM | #16 |
Rear
SOLD!!!!!!!!!!!!!!!!!!!!!!!!
Heres my hood that I looked so long for . http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT I almost missed it .I just had time to log on and put in a maximum bid .I am glad to see that I got it for only $81 . Last edited by f.monroe; 04-03-2005 at 10:29 AM. |
