Old 10-04-2004, 11:07 PM   #1
Swbman
Need to Replace 16.5 Rims on Burb,whats a good Donor..
On my 71 3/4 burb Ive got those old 16.5 rims and tires,looking for a donor truck to give up its 16 inch wheels and tires and possibly center caps.hopefully something I can find in my local salvage yard.
1961 BUICK LESABRE ** 1968 CHEVELLE SS 396 ** 1969 BUICK RIVIERA GS ** 1971 2 WHEEL DRIVE BLAZER ** 1971 4X4 BLAZER ** 1971 SHORTBED CHEYENNE FLEETSIDE ** 1971 SHORTBED 4X4 FLEETSIDE ** ...My Ebay
Swbman is offline   Reply With Quote
Old 10-05-2004, 10:46 AM   #2
crews
It just doesn't matter
You should be able to locate some 16" steel wheels from the 88-2000 3/4 ton trucks or Burbs. They are a bolt on, and should be quite plentiful.
Also check out come of the new take off suppliers. Sometimes you can buy like new take offs with tires mounted and balanced quite reasonable.
Bear in mind that you will need new tires when you drop to 16". Not trying to insult your intelligence, just a friendly reminder
Later-
Joe(crews)
05 Chevy Silverado..... A rogue BMW guy....
If you don't like me- TAKE A NUMBER; There are people ahead of you!!
crews is offline   Reply With Quote
Old 02-12-2005, 01:29 PM   #3
wagonhoe
wagonhoe's Avatar
I bought two sets of "takeoffs" from local swapmeets (Pomona and "Big 3" in San Diego) for less than $150 each for 4 rims, good tires and center caps for my 1/2 ton 68'. They were from the 99-02 Silverados with the six lug pattern. Make sure you get the correct caps. The first set I got had the wrong caps and didn't fit within the center hole of the rim. I believe they were from a tahoe. The only thing I had to do was buy spacer plates ($40ea) to kick the rims out a bit. The center holes were just a tad too small to go over the burbs hubs. They also gave me a wider track since the newer rims were offset to the outside rather than the middle. The spacer plates moved them out about an inch and had their own wheelstuds offset from the originals.
Big 3 Parts Exchange is February 25, 26, 27
www.Big3PartsExchange.com
Pomona is March 6
wagonhoe is offline   Reply With Quote
Old 01-13-2006, 12:25 AM   #4
72freak
Rottenwood Garage Member
72freak's Avatar
Re: Need to Replace 16.5 Rims on Burb,whats a good Donor..
I would imagine that you have 8 lugs? If so...just about any 8 lug wheel will work from the early 70's and up.(with front disk brakes) GM, Ford or Dodge. Ford changed about 1999 and went metric so the wont work after that year. You want 8 on 6.5.... I bought a couple of sets to change out the 16.5's. A set of Ford steel wheels with chevy dog dishes $10 each and then I also used a set of Hummer H-2 wheels $40 each with newer Chevy dually center caps $5 each for a completly different look. See my first post...it has pictures.
72freak is offline   Reply With Quote
Old 01-13-2006, 08:29 AM   #5
olblue60@aol.com
member
OOps
I started to reply about the Hummer wheels and noticed it suggested in the previous post. Good luck!
John
1967 C/K10 Chevy Panel
1968 C/K20 Chevy Pickup
1968 C/K10 Chevy Suburban
1941 Chevy Sedan Delivery
1960 Chevy Sedan Delivery
1972 Camaro SS 396 #s matching
1971 Harley FX Superglide
olblue60@aol.com is offline   Reply With Quote
