Old 10-04-2004, 11:13 PM   #1
Swbman
Need to Replace 16.5 Rims, on my 3/4 ton,know any good donors.
I need to replace the old 16.5 Rims and tires on my 3/4,does anyone know of any good donor truck I can get the 16 inch wheels and tires from, something I can find in my local salvage yard,dont want to spend a lot $$$$$. thanks
1961 BUICK LESABRE ** 1968 CHEVELLE SS 396 ** 1969 BUICK RIVIERA GS ** 1971 2 WHEEL DRIVE BLAZER ** 1971 4X4 BLAZER ** 1971 SHORTBED CHEYENNE FLEETSIDE ** 1971 SHORTBED 4X4 FLEETSIDE ** ...My Ebay
Swbman is offline   Reply With Quote
Old 10-04-2004, 11:16 PM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
My uncle had replaced the 16.5 rims on my 72 C/20 with a set of 16's off a mid 80's up Ford 3/4 ton...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 10-04-2004, 11:20 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
mine look to be from later model vans. I'n not 100% sure as they were given to me.
I know 87 burbs had 16 inch rims.
Old 10-04-2004, 11:47 PM   #4
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
All the 8 hole patterns are the same,ford,chevy,dodge.if the center is big enough to clear they'll fit.
I would just go walkabout the local yards and see what I could get a hold of.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 10-04-2004, 11:57 PM   #5
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Ford 8-lug went metric in the late models... Sorry dunno what year that started. I swapped my 16.5's for 2004 Suburban. Tires and alloy wheels $400. That's super good deal! If you like em, not everyone does, inquire who does the take-off conversions from your local GM dealer and go from there.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 10-05-2004, 12:01 AM   #6
1969 GMC
1969 GMC's Avatar
Yup all Ford Super Duties have the 8x170mm oddball pattern, so they won't work.
However, the F250's and F350's wheels on '97 and older will work. Newer Ford vans are still 8x6.5 IIRC, so they will. Watch out for the oddball 7 lug found on some light duty F/E250's, though.
All GM wheels to present should work, but the center hole may not be large enough to work for you. If you want some "Bling" get the chromed alloys or even the H2 rims (17x8 I think).
Dodge has gone metric too IIRC, but I don't know anything about that. Any thing from the 70's up to 93 will work for sure, but it gets fuzzy after that.
Good luck!
EDIT: the takeoff rim and tire packages are cheap! I just talked to a guy on Pirate4x4 who bought ebay H2 rims for his truck, he bought a set of 5 rims only for $177 + shipping. Talk about a deal! Check tire stores if there are any around you, because a lot of ppl buy new trucks and take them straight to the tire store to get some blingin du(m)bs and lo-pros, and you can score the stockers for cheap.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 10-05-2004, 12:24 AM   #7
justplainjoe
justplainjoe's Avatar
I just replaced my 16.5s on my 72 3/4 GMC. I was gonna use take-offs from a newer GM but the wheels were too tucked into the wheelwells and I didn't like the look. I ended up lay'n down some cash for custom wheels and 6 ply tires in the end. I'm happy I went that way, and so is the wife.
03 Tahoe LT 4x4
04 Corvette
99 Cadillac SLS
72 GMC 2500
04 Jeep Rubicon
justplainjoe is offline   Reply With Quote
Old 10-05-2004, 12:36 AM   #8
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
Originally Posted by 1969 GMC
...IIRC...
i have figured out what most of the acrynoms are but i dont know what this means.
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 10-05-2004, 12:44 AM   #9
Longhorn Man
If I Remember Correctly
I just figured that out recently.
Old 10-05-2004, 12:47 AM   #10
68w/sbc406
68w/sbc406's Avatar
LMAO LMFAO IIRC WTB and i am sure there is more. thanks longhorn
Old 10-05-2004, 12:48 AM   #11
1972C10
1972C10's Avatar
Kinda like the old David Allan Coe Song x's and o's
1972C10 is offline   Reply With Quote
Old 10-05-2004, 12:55 AM   #12
chickenwing
There is no machine work required on the H2 wheels? I remeber some guy on ebay selling information on how to modify H2 wheels. Maybe it was for the lug nut cover?
