Old 10-05-2004, 12:14 AM   #1
charlieo
Divorced transfer case
I just got done mounting a 69 cab on my 74 blazer frame & the top of the transfer case (NP 203) hits the floor pan just a little . Whats involved in divorce mounting a transfer case ? Would I need to build a cross member for the TC and would I swap out the rear tailshaft housing out of a regular style TH 350 then have a drive shaft made ? Anybody know ? Also whats the quality of these aftermarket patch panels everybody sells ? Thanx
charlieo is offline   Reply With Quote
Old 10-05-2004, 04:41 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
You'd need to find a divorced transfer case. I believe the NP200 and NP202 are divorced style. Now dodge and ford had divorced style transfer cases, but not sure what applications or years you'd need to find. Do you just need to cut out the low hump and bolt in a high hump? That's what I did when I swapped a 2wd auto cab on to my 71 4x4 chassis.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 10-05-2004, 09:46 AM   #3
1969 GMC
1969 GMC's Avatar
Personally I would not add a divorced case unless you really want to use some oddball 2wd only transmission. With divorced, you have to worry about one more driveshaft and 2 more ujoints.
Anyway, divorced NP203's are rare as hens teeth and are drivers drop only from Ford trucks. You would have to find a GM, Dodge, or IH divorced NP205.
Or you could just do a little floor pan surgery if you don't wanna open up the can of worms.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 10-05-2004, 10:51 AM   #4
charlieo
tc
Yea, I don't need anymore worms in my life right now (lol) The truck is a high hump but the tc hits at the very end of where the hump would end . I think it's because its a np 203 . I think I'll just raise the cab another 1/2" that might do it. Are the aftermarket patch panels worth buying , I have to get them anyway so I guess I really don't have a choice !
Old 10-05-2004, 12:51 PM   #5
gn4u2c
gn4u2c's Avatar
1' body lift !
gn4u2c is offline   Reply With Quote
Old 10-14-2004, 12:11 AM   #6
Stano
Stano's Avatar
Not to mention that a divorced TC on a blazer would make for a short rear driveshaft and it would be at a way harsh angle, heck it might even bind up on ya. My stock blazer went through rear u-joints like nothin. I ended up shiming my pinion angle up to get it to stop it. Just some food for thought.
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80
Nice ride 67 Chevy C-10 LWB Built 350 TH-400
Wifes ride and family rig:
2001 Furd Expedition 5.4 Liter
Kickin back in Rolla,Mo. USA
"Do the thing you fear most and the death of fear is certain" Mark Twain
Stano is offline   Reply With Quote
