Old 10-05-2004, 04:22 PM   #1
crustysarge
Stock seatbelt install
I am puttiing the insides back in the 72 cab and can't remember how the belts go.
When layed out flat over the seat should the buckle be up or down?
If I recall the middle belts mount under the outer belts on the hold down bolt? Also should the buckle for the middle be on pass side or driver's side when sitting in the cab?
Are the outer belts near the door the same for both sides?
One more, I see two different numbers on the pass and driver belt, end in 35 and 36. Which side is which?
Maybe next time I'll take a picture...
crustysarge is offline   Reply With Quote
Old 10-05-2004, 08:28 PM   #2
JimKshortstep4x4
The buckles lay on the seat with the insignia "up".
The middle seat buckle is on the passenger side.
The outer door belts are different. If you look at the sleeve when mounted the correct way is to have the sleeve so that it turns in toward the seat. If you turn it out away from the seat it will hit the door.
Jim
