Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 10-05-2004, 07:16 PM   #1
Cliff
1996 Chevrolet Lumina Starting Problem
Sorry for the post on the truck forum. But a really good friend of mine has a 1996 Lumina and it won't start all of the sudden. The battery on the car is new allong with the alternator. I tried to jump the car and it made no attempt to start. If you get in the car and turn the key, everything works but it makes no noise. No attempt to start at all. I banged on the starter and it made no differance. I even tried to jump the starter with a screwdriver and you can hear the relay kick out but the starter is not turning. Any tips would be greatly appreciated. Maybe some relays or something to check ? Thanks everyone, and again I appologize for the post on the truck forum but everyone here is full of tips.
Cliff
1972 Custom deluxe 305/350 C/10 8-foot bed with 1/4 inch diamond plate steel bed floor.
Cliff is offline   Reply With Quote
Old 10-05-2004, 08:30 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If you jumped the posts, then either the engine is locked up, or it is time for a new starter.
Old 10-05-2004, 10:01 PM   #3
Don Smith
It could be the anti- theft chip in the key. Try spare key, I bet it will crank.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline   Reply With Quote
Old 10-05-2004, 10:07 PM   #4
Longhorn Man
If he jumped the posts on the starter, he would have bypassed everything in the car, all switches, all relays all computer stuff. It should crank.
It is the exact same as bench testing it.
Old 10-06-2004, 12:30 AM   #5
68LSS1
68LSS1's Avatar
Providing he's getting power to the starter. Check for voltage at the starter and check the battery ground. While your at it check the battery voltage. If a battery gets too low it still won't jump. (Yes even though it's a new one someone could of left something on or did he have a charging problem seeing as you saidthe battery and alternator are new?)
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 10-06-2004, 12:33 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Make sure the engine isn't frozen up by turning the belt or crank pulley.
Old 10-06-2004, 12:40 AM   #7
longhorn71
longhorn71's Avatar
the pinion gear could be stuck agianst the ring gear this could cause the starter not to turn.remove to check
longhorn71 is offline   Reply With Quote
