Old 10-05-2004, 09:12 PM   #1
rage'nrat638
rage'nrat638's Avatar
Thumbs up Carb. Spacer For Edelbrock Carb. Update
WELL WHEN SOMEONE ASKED LAST WEEK ABOUT THERE EDELBROCK CARB...RUNNING LIKE DOG....
SOMEONE ELSE SAID INSTALL A CARB ...SPACER....WELL I ORDERED ONE FROM SUMMIT....
LET ME TELL YOU....IT ROCK'S....MY TRUCK...69 C-20 W/355 SMALL BLOCK...
HAS NEVER RAN BETTER.....
WORTH .....EVERY DIME.......
JUST A FYI......
YOUR PAL MARK....
rage'nrat638 is offline   Reply With Quote
Old 10-05-2004, 09:36 PM   #2
melloyello
melloyello's Avatar
I also run an Edelbrock carb so what size of spacer was it wood, plastic or metal part # would be great.....
67 C/20 camper special 350
melloyello is offline   Reply With Quote
Old 10-05-2004, 09:46 PM   #3
68 Stepside
huh?
68 Stepside's Avatar
I agree, give us some details Mark!! Sounds like something I should do
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 10-05-2004, 09:52 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Plastic or wood would be the best, but alluminum works too. I use a 2 inch open hole spacer.
Old 10-05-2004, 11:17 PM   #5
rage'nrat638
Thumbs up Man It's Sweet
this bad boy came with the correct stud's....and two new gasket's.....
every thing needed to put it on......took about 15 min....
EDL-8710
More low-end torque and a cooler carburetor.
Carburetor Spacer, 1 in., Open, Phenolic, Black, Each
These Edelbrock carburetor spacers allow you to space your carburetor above the intake flange to increase plenum area for more torque and horsepower. Available in aluminum and heat-insulating phenolic or wood fiber, these Edelbrock carb spacers are just what you need to insulate or tune your carburetor/manifold powerband.
Vendor Edelbrock
Product Line Edelbrock Carburetor Spacers
Carburetor Spacer Material Phenolic
Carburetor Spacer Style Open
Thickness (in) 1.000
Gaskets Included Yes
Mounting Hardware Included Yes
Carburetor Spacer Finish Black
Quantity Sold individually.
Notes (Not Specified)
Old 10-06-2004, 04:32 PM   #6
70short
Anybody gone with 2" allum. or plastic??? preferably the allum???
Gary
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 10-06-2004, 04:58 PM   #7
Nima
Blue 67
Spacer Wouldn't cause any clearance issue on stock engins and hood?
Nima is offline   Reply With Quote
Old 10-06-2004, 07:07 PM   #8
Longhorn Man
on a small block, with a normal sized air filter, there are no hood clearance problems at all.
I have a 2 inch on top of an edelbrock performer RPM intake, all capped off with a 4 inch tall air filter. Still have plenty of room.
Actually, i should say I HAD that set up.
Old 10-07-2004, 12:07 AM   #9
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
I just put a 2-inch phenolic spacer on this Sunday. I love the results and highly recommend the phenolic over the aluminum. You can read more about it here.
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 10-07-2004, 01:17 AM   #10
Tynee
I miss this truck.
Tynee's Avatar
I'm running the 2" with a stock intake, Ed. 1406, and 4" filter. No clearance problems, but can't speak to performance since I never tried without the spacer.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 10-07-2004, 02:56 AM   #11
69ChevyLB
Active Member
69ChevyLB's Avatar
Question spacer
Anyone used a spacer with a Holley spreadbore? Any difference in performance?
69 C10 LWB Project
47 Cushman Scooter Project
It is better to have loved and lost than to live with a psycho all your life.
69ChevyLB is offline   Reply With Quote
Old 10-07-2004, 03:12 AM   #12
ZOOMY
price
$24.78 (plus shipping) from Northern Auto Parts. Summit might be shipping included ????????
ZOOMY is offline   Reply With Quote
Old 10-07-2004, 03:29 AM   #13
'68OrangeSunshine
'68OrangeSunshine's Avatar
I have a Carter AFB 600CFM 9605 [=Edbk 1405] on a 350 in a '71 Jimmy. Last week the carb started running rough. I R&R'd the accelerator pump plunger, but had problems when I tried to put it back together -- the needle valve caught on the driverside float and the float level got bent in reassembly. So I had to haul it off the block and re-carb. Once I pulled the AFB, I saw I had a velocity stack of some paper gaskets and aluminum templates that I had forgotten about. Maybe one of my buddy's ideas. (I wondered where that vacuum leak/high-pitched whistle was coming from.) Anyway once I rebuilt the carb I started looking around the shop for some Carter/Edelbrock gaskets and found -- a 1/2" phenolic squarebore spacer. Since I had been following this thread, I knew what it was good for!
After a good cleaning the carb went together ok. The engine never ran smoother.
Good call guys.
Old 10-07-2004, 03:22 PM   #14
70short
FYI- I called Schucks auto supply here local. They quoted me $29.99 for the edelbrock-8713 carb spacer. Summit is asking $33.95. It pays to check around.
Gary
Edel 600 cfm carb
HEI
shorty Headers
4/2 Drop
"CHEVY RULES"
Old 10-07-2004, 03:26 PM   #15
fine69
fine69's Avatar
Do they make them for Quadrajets?
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 10-07-2004, 04:14 PM   #16
Nima
Blue 67
I don't mean to change the subject but Does anybody know the difference between the 4 hole spacer and one piece ones?
Old 10-07-2004, 04:53 PM   #17
cali_surfer
cali_surfer's Avatar
Has anyone had problems with the throttle rod when running a spacer?? I have a rod, not a throttle cable, and when i went to go put on a spacer the linkage would bind up....... never had time to fix it, so the spacer is just sitting on the shelf collecting dust. What has everyone done?
My engine is stock... trust me ;o)
cali_surfer is offline   Reply With Quote
Old 10-07-2004, 07:47 PM   #18
Longhorn Man
Mike, i have a spare I'll try to remember to bring it to you. It'll fit under a quadra jet.
I have a throttle rod on mine, and never had a binding problem, and that is on top of a sorta-high rise intake.
Old 10-08-2004, 12:07 AM   #19
shuttermutt
Same here. I've got the 2-inch spacer on top of an Edelbrock RPM and my linkage works a treat.
'Mutt
