Garage Queen Material
MF!!! thats no good!!!
i swear, i fix one thing, and another freaking thing breaks!!
i took off my valve covers today to polish them. got them all nice and pretty and put them back on. when i go to tighten one of the nuts on the stud, it cracks the damn valve cover!!! is there anyway to fix this? its leaking slowly whenever i drive it. |
they are alum right? the only thing to do is get it welded up, and then smooth it back down.
Daily Driver: 1992 Blazer dropped on rallys ![]() Project: 87 GMC shortwide, About to get a little boost ![]() |
HAHA . I did the same thing With a pair of M/T's I cracked one of them Tryin to get a leak to stop . Dont put so much S*** down on it next time...
Shouldnt cost but 20 dollars or so to get it fixed have it welded on the inside Clean the crack out with a die grinder and wouldnt hurt to drill the end of the crack to prevent it from spreading.. Alot of metal shops prefer to do their own prep work though so call around first. |
Workaholic
I told you in a post way back to stick with chrome and you would not have to deal with the polishing
![]() Seriously though, that sucks--I guess by the time you paid someone to weld it and deal with all of that you could buy another set. If you used a torque wrench to the Mfg specs maybe you could get a warranty claim as defective?.?.? |
maybe try using some of those spreaders that spread the pressure out instead of putting it all on the one spot.
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
california fill
well now you know you were torqueing it way too tight. same with stamped valve covers and oil pans, install the screws with a nut driver and just snug em up good. Then re-snug in about a week. It should be a crime to touch pan/V.C. bolts with a wrench
I use a little 1/4 rachet for all my oil pan and whatnot tightening If you get carried away you can overtorque with a nutdriver Just the same as anything else.
I use those T-Handle valve cover bolts, I love those things!
#9 | |
Put a coat of J-B Weld on the inside of the cover where its cracked. Ive used that stuff for almost everything & its never let me down yet...corn
Torque on valve covers is rated in inch pounts not pound feet. "Snug" is all it takes with good gaskets.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
my dad called jegs today and they said we could ship them back and get another set
![]() that means i'll have a nice clean set that i will use a torque wrench on from now on ![]() i love jegs!!! i'm using my friends moroso stamped valve covers now, and no leaks. what would you guys recommend for a gasket that would work really well? |
#13 |
Fel-Pro Gaskets are good.Never hava had any problems with them leaking and have been on the truck for the last 5 years.
![]() Midwest All Truck Nationals, Riverside, MO - 2008 - 2015 Last edited by 86 Red_Bowtie; 10-12-2004 at 08:24 PM. |
#14 |
You get what you pay for
![]() Join Date: Dec 1999
I have always used Mr. Gasket Ultra Seal valve cover gaskets and to this day, never had a leak. I glue them to the valve cover and can remove the covers without messing up the gaskets.
Mike 1985 Chevy C-10 |
#15 |
fel-pro glued to the valve cover
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
#16 |
Gentleman Jim Driver
I really like the high end line of Fel Pro Permadry plus gaskets. They are expensive (~$40 at Autozone) but they work great. They are rubber like modern factory gaskets and go on dry. They are reusable and have inserts to prevent overtorqing.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
#17 | |
Happy to be here
![]() Join Date: Mar 2000
#18 |
i'm very happy with jegs about this. they didnt have to take them back, and most places wouldnt, seeing as i ordered them back in febuary.
#19 |
I'm back with 2nd truck!
I've lucky enough to not break mine but mine are centerbolt style though. Not sure if that has helped or not. I use the fel-pro style for my truck.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
#20 | |
DAMN, I love Big Blocks!
Marc Bona Hobbs, New Mexico 1976 1/2 ton GMC High Sierra. 454 c.i.d./ TH400. *Soon to get a mild warming over.* 3.40 rear. ![]() |
#21 |
So far I like the Moroso blue rubber gaskets.
I was using the fel-pro rubber, but they have these ridges that I think make them less affective. The moroso valve cover gasket i am speaking of is very similar material and texture to fel-pros 1-piece oil pan gasket. I highly recommend them.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
