Old 10-05-2004, 10:49 PM   #1
Peregrine
Peregrine's Avatar
Light truck?
After driving my truck for almost a week I realized what it is that feels different. It feels a lot lighter to drive than my dads 82. I know power steering throws you off, but it just feels weird. When I go into a corner at 40 it just feels really light. The thing stops on a dime and picks up that extra 15 mph to pass people damn quick. Is a 72 lighter than an 82? Oh well. And what kinda RPM do you guys turn on the highway around 70 mph? Guys with a 350/th400 anyway
Brian
72 C10 longbed 350/th400
Let the world change you and you will change the world.
Peregrine is offline   Reply With Quote
Old 10-05-2004, 10:55 PM   #2
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
sb406/th350 at 70 i am around 3500 with a 3.73 rear. i ran my truck over the scales and it came in around 3900lbs. i think it might have something to do with older softer worn out springs and shocks. just a guess
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 10-05-2004, 10:56 PM   #3
1972C10
1972C10's Avatar
My 72 turns 3000+ at 70mph 350/10"Stall /th350/3.73
1972C10 is offline   Reply With Quote
Old 10-05-2004, 11:17 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If you have a small block and automatic, then you probably have a 3.07 gear which would put your RPMs right about 2500 @ 60 MPH
These trucks handle better than the 73 & up, that may be what you are feeling.
Old 10-05-2004, 11:19 PM   #5
Peregrine
Peregrine's Avatar
Must be. It came with a V6 from the factory (don't know what at the moment) and I turn around 3 grand like the others.
Brian
Old 10-05-2004, 11:41 PM   #6
Longhorn Man
if it is a chevy, then it was an inline 6...only GMC trucks had v 6 motors.
3000 RPM sounds like 3.73's to me.
Old 10-06-2004, 02:43 PM   #7
Peregrine
Peregrine's Avatar
It has a 12 bolt rear though, so?
Brian
Old 10-06-2004, 07:42 PM   #8
68 Stepside
huh?
68 Stepside's Avatar
12 bolts could have had 3.07's (V8), or 3.73 (I6) in 67-72 standard I believe. Just because it's a 12 bolt doesn't mean that it has a particular gear in it.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 10-06-2004, 07:50 PM   #9
gmc67swb
gmc67swb's Avatar
2100 RPM at 70 with 3.55's out back.
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
Old 10-06-2004, 09:28 PM   #10
Longhorn Man
Notice, the 5 speed in his signiture. These numbers won't help you at all.
Pop the cover off the rear and count the teeth. The oil is probably 20 years old in there anyways.
Old 10-06-2004, 09:45 PM   #11
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
It seems that my truck came in somewhere around 4000 lbs, with my fat butt in the seat....heck, coulda been even more.
My truck has 3.07 gears, as stock. With the TH400, I have no idea how many RPM's it is turning at 60MPH, but there's still some pedal left, if I want to use it.
As for cornering, you gotta remember that the setup for coil spring suspensions, is what NASCAR uses on their race cars...same type of trailing arms, that is. With some lowering, it just gets better and better!!
Member Nr. 2770
