Does anybody know how many body mounts are on a 1980 Blazer? Are they hard to change? Do I need to lift the body off or can I do one at a time?
Thanks, Doug |
Slots go on anything!
there should be 10 or 12, I don't recall which. The hardest part will probably be getting the bolts loose. The best way is to do one side at a time. Get enough clearance to get the mount in and out, should be all you need.
1974 Jimmy- 5.3/4L80e/NP241 |
Thanks JONBOY. I thought there were only about 8. Geez a lot of work. Nov 1 she is away for the winter so I guess I will have time.
Thanks, Doug |
