Old 10-07-2004, 08:19 AM   #1
1987SierraClassic
Fuel Gauge
I have an '89 Suburban. When the tank is about 1/2 full, the fuel gauge 'wigs out' bouncing between 1/2 and Full. I'm suspecting the gauge is bad. My 1/2 ton pickup did the same thing until I tightened the connector behind the instrument cluster, but the same fix didn't work on the 'burb!
Anyone seen this behavior before?
1987SierraClassic is offline   Reply With Quote
Old 10-07-2004, 09:16 AM   #2
rockman20
"The dude abides"
rockman20's Avatar
I have never messed around with fuel gauges much, but it sounds to me like the sending unit in the tank.
RockMan
1993 Chevy Silverado C3500 1 ton dually
1994 Honda Civic
1969 Oldsmobile Cutlass S
1953 IH Farmall Super M
New to the fleet:
1992 Subaru Loyal
rockman20 is offline   Reply With Quote
Old 10-07-2004, 08:57 PM   #3
cliffsta
Stepsides RULE
cliffsta's Avatar
generally, feul gauge probelms are the sending unit. My gauges is top-sided; drops real slowly when full, then falls off past halfway on the gauge and goes past F and E. Pretty much its a sending unit problem, as its the weak link in the whole system i guess.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 10-08-2004, 08:58 AM   #4
1987SierraClassic
I really don't want to drop the tank, but I suppose I will have to sometime!
Old 10-08-2004, 09:01 AM   #5
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Defiantely sounds like a fuel sender like others mentioned. While you're there you might want to invest in aa completely new tank and sending unit if you're tank is old or rusting. Also incluse with that new straps and rubber lines.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 10-08-2004, 09:05 AM   #6
1987SierraClassic
Believe it or not, the underside of this truck looks like it just rolled off the assembly line. I can read the part number stamped on the frame. No rust at all as it came from your neck of the woods (somewhere in TX). The tank is mint as are the straps, so I'm not too worried about that. If I drop the tank, I'll replace everything while I'm there! It's not worth it not to!
