Old 10-07-2004, 01:01 PM   #1
jpaitala
Custom Truck, here I come
jpaitala's Avatar
Summit 2" drop springs...
I just finished installing the 2" drop spings from Summit racing and I'm not completely satisfied with the outcome.
The distance from wheelwells to ground was 35,5" before the drop springs and now it's 34,8", so not even 1" of drop achieved....
Any similar experiences?
Ps. There's no engine on the truck, could that be the reason for such a lame drop?
Thanks.
Check out my homepage!!!
-'74 Cadillac Eldorado
-'00 Ford SuperDuty 7.3
jpaitala is offline   Reply With Quote
Old 10-07-2004, 03:04 PM   #2
Joe67
67 is sold
If your original springs were very worn, you wouldn' notice very much of a drop.
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 10-07-2004, 04:10 PM   #3
78SilveradoSWB
78SilveradoSWB's Avatar
I think the springs need to settle in and without any engine, there is little weight to settle them in to.
Mitch
1978 Chevrolet Silverado C 10
454 BB, TH400
78SilveradoSWB is offline   Reply With Quote
Old 10-07-2004, 04:44 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I run Summit 2 inch front springs in several of my trucks, including my current one.
Likely your original springs are sagged over time.
Wait till the engine is back in to judge.
Old 10-07-2004, 11:41 PM   #5
jpaitala
jpaitala's Avatar
The original springs are from Diesel Truck.... Since my truck was originally equipped with a diesel engine, if that counts....??
I'm thinking of taking one round of spring off.
Or is that a absulutely insane or something?
Old 10-08-2004, 07:44 AM   #6
Tx Firefighter
Don't do it man.
I guess you're talking about Summit brand springs, the bright blue ones? Those are actually "Ground Force" springs if you look real close. A good quality spring.
Put the engine in it first. You'll be happy with them. I have 2 sets in use right now, one in my green truck, see signature, and the other in my Blazer too. I have lowered other trucks with this exact spring in the past. I wouldn't keep using them if they didn't work right.
Old 10-08-2004, 02:00 PM   #7
jpaitala
jpaitala's Avatar
I just measured the original spring at the highest point 13,5" and the Ground Force 2" drop spring is 12,5" at the highest point...
I'm having a bit of an moral crisis here... The other side tells me to cut the springs a little and the other side says no.
I think I'll have to sleep over the night and decide tomorrow.
Old 10-08-2004, 05:04 PM   #8
Tx Firefighter
Dude, you're screwing up.
Put the freakin engine in it first. Then, if you want more drop (you won't) you can cut it.
I'm telling you, I have 2 trucks right now with these springs in them. You will be happy. Put the engine in first and decide before you ruin an 80 dollar pair of springs. You can always cut them later, but you might be sorry if you act too soon.
Old 10-08-2004, 11:22 PM   #9
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
the height of the unloaded spring has nothig to do with it's actual ride height.The coils could even be the same length,and still achive 2 inches of drop.Wait til you get the engine in it.
The coils on the drop springs aren't as strong as the stock coils.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 10-08-2004, 11:44 PM   #10
jpaitala
jpaitala's Avatar
After sleeping over the night now I'm thinking the same as you guys are.
So I'll be leaving them as they are now... And wait until the engine is in there.
Thanks.
Old 10-09-2004, 12:17 AM   #11
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
does summit have coils for 67-72s?
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 10-09-2004, 01:37 AM   #12
Brainchild
Brainchild's Avatar
I think you'll be smiling when you drop the engine in there jpaitala
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
Old 10-09-2004, 03:19 AM   #13
jpaitala
jpaitala's Avatar
That's what I'm really hoping...
Old 10-10-2004, 02:12 AM   #14
corn
I have 2" lowered spring & 3" drop spindles. I dont have an engine it my truck either & it sits like a 4X4. Dont worry, wait for the engine...corn
corn is offline   Reply With Quote
Old 10-10-2004, 09:46 AM   #15
Z28Owner
Z28Owner's Avatar
ttt
1971 LWB Chevy C-10
350/350 3:42 eaton
Z28Owner is offline   Reply With Quote
Old 10-10-2004, 12:27 PM   #16
Tx Firefighter
Originally Posted by Z28Owner
ttt
73-87 coils directly interchange. Order 73-87 part number.
By the way, Summit springs are actually Ground Force brand. Good stuff.
I have a set under my Blazer and a set under my little 70 truck.
Old 10-12-2004, 02:14 PM   #17
TIMSPEED
TIMSPEED's Avatar
I aswell have those "Ground Force" 2" Drop springs on my truck. Like others have said, they're good quality, and DO drop your truck 2". On mine, before I put them in, it didn't sit level...now, with them in, it sits perfectly level. Trust me, get the engine in there, and you'll be singing a different tune.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 11-03-2004, 01:21 AM   #18
ChevyDude
I also have those same coil springs and would not cut them...no way!
Alex
1971 Lil' Red 350 SBC 700R4
ChevyDude is offline   Reply With Quote
Old 11-04-2004, 01:58 AM   #19
jpaitala
jpaitala's Avatar
The rear of the truck looks real good now as I installed the 4" drop in the rear a few weeks ago. It looks like a drag car now in the start of the quarter mile race with it's nose up.... I'm anxious of getting the motor in - someday....
