Old 10-07-2004, 02:04 PM   #1
lewi
lewi's Avatar
towing capacity ???
I am considering buying a toybox trailer. I currently tow about 5000 lbs and don't have to slow down in the montains, doesn't shift down with the 350 trans on all but the steepist of grades. My thoughts are towing closer to 12,000 to 15,000 lbs loaded and how the truck will handle that. I have a new tranny cooler, 4 core radiatior, and rebuilt tranny and rear end. The moter is new 383 running 9 to 1 with edelbrock 600, headers and so on.
My question is ......Is anyone else already doing this? My other option is to keep the enclosed trailer I use now and buy a motor home, but that is alot more expensive.
1971 Chevy Cheyenne 383/350 LWB 2wd
Built to use, and look good.
lewi is offline   Reply With Quote
Old 10-07-2004, 04:07 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Acording to the book....and asuming you have 3.07 gears, with a 350 you can tow 6500, and with a 402, you can tow 7000...another asumption is that your ride is a half ton.
Old 10-07-2004, 06:36 PM   #3
Robert1970C20rstbukt
Robert1970C20rstbukt's Avatar
The max. GVW rating on my truck is 7200lbs, mines a 3/4 ton. I think it's 11000 for a 1 ton, then you get into the medium/heavy duty 40-60 trucks after that.
RJD
1984 Chevrolet C30 welding truck 454/SM465
1977 GMC C15 pickup 350/TH350
1970 Chevrolet C20 pickup 350/TH400
1970 Chevrolet K20 Suburban 454/TH350
1969 GMC 8500 478M V6/5 spd winch truck
Robert1970C20rstbukt is offline   Reply With Quote
Old 10-07-2004, 07:41 PM   #4
Longhorn Man
The GVW is the weight the truck can max out at, not what it can tow. You would want the CGVW for that number. (Combined Gross Vehicle Weight) Not all trucks in the same class had the same GVW, my one ton has a GVW of only 9000 pounds.
Old 10-08-2004, 04:09 PM   #5
lewi
lewi's Avatar
You guys are on track. After checking yeaterday it looks more like 10,000 to 12,000 pounds loaded for the trailer. I am wondering what the weight rating is based on, the braking power of the truck only? With electric brakes and a torque oriented 383 where would I have problems with the wieght???? Does anyone else tow heavier trailers??? Is it a drivetrain issue??
Old 10-08-2004, 04:12 PM   #6
lewi
lewi's Avatar
I see huge trailers and or 5th wheels being towed by pick ups all the time, I'm just trying to figure out if the "Old Girl" is up to the task?
Old 10-08-2004, 08:45 PM   #7
Longhorn Man
Well, the specs I listed are from dealers books, and the capacity goes up with towing gears, and also goes up with bigger engines.
In all reality, that sucker will probably tow what ever you hook up to. I have towed a 5 ton GMC Flexible bus (think big city inner city bus...rear mounted 318 V-6 detroit) for almost 5 miles about a year ago. I was haul;ing it about 45 - 50 MPH...he was doing all the braking.
Old 10-08-2004, 09:44 PM   #8
Tynee
I miss this truck.
Tynee's Avatar
Andy, do you by chance have pics pulling that bus down the road? I bet that looked FUNNY!
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
Old 10-08-2004, 09:48 PM   #9
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
that would have made a good chevy/GMC comercial
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 10-08-2004, 11:05 PM   #10
Longhorn Man
no, no pics.
It was at work, all the shop trucks were out except the flat bed which is an F-150 300/5 speed which has something like a 2.73 in the rear axle...that thing can hardly take off without a load...let alone a 5 ton brick tied to the bumper, so i had to take my truck. The dude was on a test drive after replacing the heads. The f;eet manager didn't want us to deck the block, just said replace the heads. It blew BOTH head gaskets on the test drive, and couldn't pull it's own weight.
I wanted to tow him faster, but he would tap the brakes and almost make me kiss the steering wheel, so I held it at 50. Got some funny looks as I was buzzin down the road with a 40 foot chain and a huge friggen bus on the back.
No pics. this was while I was between camers. I think it was right after leaving the Fuji digi-cam in the rain.
Old 10-08-2004, 11:35 PM   #11
Longhorn Man
It was one of these suckers.
