10-07-2004, 03:10 PM | #1 |
Clicking Noise
I fired up the truck last night and I am hearing a clicking coming from the passenger side head. Sounds like it is coming from #8 or #6. What does a clicking valve mean?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
10-07-2004, 03:46 PM | #2 |
Cantankerous Geezer
It depends on just what is clicking. Usually it's a lifter that's gummy. If that's it, try adding a can of Rislone engine treatment to the oil. It might help. Also, open the valve cover, be sure the valve are operating correctly.
If it is a sticky lifter, and the Rislone doesn't stop the noise, the next step is new lifters. But as long as the lifter is working properly, the noise doesn't hurt anything. It just bugs the heck out of you.
Fred There is no such thing as too much cam...just not enough engine. |
10-07-2004, 05:39 PM | #3 |
I would also look even closer and ensure its not a small exhaust leak
2008 Buick Enclave(wifes new non wrecked) 1996 Jeep Cherokee 2002 2500HD 6.0L (traded) 1998 Jeep Grand Cherokee(wifes/wrecked) 1977 DJ5 postal jeep(mmm lots of fun) 1988 Toyota 2wd p/u(DD, blewup 199,000) 1991 Toyota 2ed p/u (sry just cant break these things) 1997 XR70 Honda 1991 Z50(FOR SALE) 1972 Z50 Honda 1970 SWB 350/knucklebuster "The adventure begins and I am confident that there will be no end". |
10-07-2004, 05:44 PM | #4 |
Thanks. I will check the exhaust manifold first tonight then go for the lifter check. I think its the exhaust manifold. I will reply back what I find.
10-07-2004, 07:44 PM | #5 |
its all about the +6 inches
Could also be a rocker out of adjustment, or a rocker pulling the stud out of the head, or a cam going flat which increases the valve lash.
10-07-2004, 08:21 PM | #6 |
Franko72
if it is constant its possibly an exhaust gasket leak,if intermitant could be a lifter or rocker arm. get a stethiscope or a broom handle and listen to the affected area for either valve train noise or exhaust pecking thru a leaky gasket
1972 C20 cheyenne Super 402 BB/400 turbo LWB A/C Tilt, Cruise Control, Saddle tanks, Tach My Home Page Better to burn out than it is to rust |
10-08-2004, 12:25 AM | #7 |
Well I think I found the problem. Ramhorn bolts near# 6 and 8 were loose. I tightened then up and started the truck. The click is still there but a lot quieter.
10-10-2004, 02:06 AM | #8 |
Update:
One of the nuts going to the pipe was a little loose. 1 full turn later then start up the truck and no more clicky. Thanks for all the help.
10-10-2004, 02:15 AM | #9 |
Its Magically Delicious
i had a few loose exhaust manifold bolts on the passenger side one time .... got on it pretty good to pass a few cars and blew a big chuck of the gasket out .... cheap and easy fix .. but it really worried me for alittle bit (was horribly loud)
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
