10-07-2004, 06:22 PM | #1 |
What kind of welder are you using?
Ok I have decided that I am going to get myself a welder. I have talked to a few people and have some ideas about what I am lookng for but I am curious what people on the board are using and what they may recommend for a rookie. So let er rip
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
10-07-2004, 06:33 PM | #2 |
PROJECT 7DEUCE
millermatic 135 I just love the little blue machine it does everything I need it to
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
10-07-2004, 06:47 PM | #3 |
Designated A-hole!
Hobart Handler 135 (built by Miller but slightly less expensive). Does great work. Picked it up 2nd hand with regulator and co2 bottle for $300.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
10-07-2004, 07:02 PM | #4 |
Member since 2000
Miller MillerMatic 135!!!
10-07-2004, 07:06 PM | #5 |
Skokie,
I got a Handler 135 and krue is right it is less expensive and work absolutely awesome. With miller you are paying for the name. I got mine at Tractor Supply Company which are all over Texas. Doubt Cali has them but I could be wrong. There are a lot of good deals on them on eBay and if you search for Hobart 135 on the web you will find some good prices at various tool supply and welding supply stores. Alot of them will ship free. Don't have any recommendations on websites because its been about a year and half since I bought mine.
My girlfriend caught me cheatin on her with another woman and now she's threatening to tell my wife! ____________________________________ 71 Chevy lwb Rough and Ready Baby!! |
10-07-2004, 07:09 PM | #6 |
Krue
What do you mean by co2 bottle?
10-07-2004, 07:21 PM | #7 | |
Designated A-hole!
10-07-2004, 08:36 PM | #8 |
I just bought one at Harbor Freight for $175. It's a Chicago Electric 131, gas / no gas option. I think the 2 year warranty cost another $30. The sale ends on those on the 18th. I still haven't decided if I'm going to keep this one. I'm interested in learning to weld, and since the local votech schools don't have evening classes I was going to learn on my own, but still haven't decided if this is what I want to do. Over the last 10 years, I've only needed something welded like 1 time. I can't justify the welder for that kind of use. I just want to say that I know how to...
10-07-2004, 09:31 PM | #9 |
Still drivin' a Rat Rod
I have 2 Linocln welders Handy core and a Arc welder
Very satisfied with both.I have had the arc welder for a couple of years,and one like it for several years before that.I like Lincoln gear,so I stick with it.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
10-07-2004, 09:37 PM | #10 |
Millermatic 175, co2/argon mix. Love it.
Brian Pal 1971 Cheyenne 10 454/th400-Undergoing a full frame off resto. 1972 Chevy short/step 2wd, 350/th350 1983 M1009 CUCV Military K5 Blazer 1981 Dodge 1 ton 4x4 dually flatbed |
10-07-2004, 09:42 PM | #11 |
The Hobart comes ready to weld with a free spool of flux core wire. Krue is right though. It comes with the attachments to add gas and you should really work on your truck using a gas shield. It makes cleaner welds and less splatter to clean up after the fact. With gas you have to turn it up a little hotter though, so you may have to play with your setting until you get the right amount of heat without burning through the metal. Of course if you weld it like ebfabman shows, you will be laying a lot of spot welds until the metal is "stitched" together. You be laying long runs of beads because that heats the metal too much and can cause warpage.
10-07-2004, 09:49 PM | #12 |
Lincoln Electric Pro MIG 135! Bought it at Lowes to about $450.
You'll need a bottle of Ar/CO2 gas which will cost about $60 bucks for a small bottle. Refills are around $18. I'm a 1st time welder, but this machine makes it almost easy. However...if your welding sheetmetal...patience, technique and accurate settings on the welder are absolutely essential. Jim Mt Juliet |
10-07-2004, 10:04 PM | #13 |
http://www.lowes.com/lkn?action=prod...8-1703-K2159-1
That was one of the ones I was looking at. Do you have to use gas?
10-07-2004, 10:26 PM | #14 |
Member since 2000
If you can deal with dirty welds. The differance form using non-gas and gas welder is like night from day. I highly suggest getting a gas welder.
10-07-2004, 10:27 PM | #15 |
Lincoln SP100T - 110v gas/gasless wire feed (it's the industrial version of the Weldpak series). I used it occasionally for the first couple of years with flux core wire before I bought an argon/co2 bottle...wow! what a difference! Go with gas, go with gas, go with gas! You will NOT regret it.
I believe with most of the Harbor Freight/low $$$ welders the wire is hot all the time, so it's possible to inadvertantly strike an arc...no bueno. Lincoln and Miller machines don't do this.
'71 C20 Camper Special |
10-07-2004, 10:31 PM | #16 |
Sounds like the gas is the way to go. What is it that the gas does ot help in the welding. After reading that it sounds like a stupid question but hey how else do you learn?
10-07-2004, 10:46 PM | #17 |
Insert funny comment.
Another Hobart Handler 135 here. Northern tool often has them on sale with a free cart! Pick up a bottle for it and your all set!
------------ - Mark -My Build Thread... -68 C10, LT1 - Undergoing Frame off resto -86 IROC-Z T72 turbo 355, M6 -70 Camaro http://www.iroc-ss.com |
10-07-2004, 10:48 PM | #18 |
Sisyphus was my mentor!
lincoln sp-135 plus. Its been nothing but an awesome gas mig welder, VERY controlable, quality machine & well priced. I totally got my monies woth.
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
10-07-2004, 11:01 PM | #19 |
Gas for a mig welder shields the molten puddle of metal. It is the same as the slag on the stick electrodes, or the flux in the flux core wire, except it is much cleaner. Argon blends are cleaner than CO2. I have a Millermatic 185, a Miller Trailblazer, and an O/A rig. I learned to weld with gas and it taught me a lot about the puddle. Then I moved on to stick welding, learned a lot about penetration, fit up, and amperage. MIG is by far the easiest route to go. Look at some pictures, find a welding BB, post some pictures of your welds, and you will recieve advice o'plenty. I am partial to Miller products, but there is nothing wrong with Hobart, Lincoln, et al. I would stick with a brand name that you recognize, so you will be able to get parts for it for a long time. Also, stick with american made wire, the cheap stuff will splatter more.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
10-07-2004, 11:52 PM | #20 |
I started out using my dads ??? brand stick welder, learned how to do thick metal, but wanted to be able to do cleaner welds
My grandpa (who kicks ass, btw) bought me a lincoln weld-pak 100, and some spools of flux core wire After pretty much getting to the limit of what flux-core could do, I got a friends dad to score me a regulator for argon/co2 (he owned a big machine sales co), then I bit the bullet and bought a CO2 bottle, my welding skills with mig are getting better every day, pretty soon I'll be starting on a new truck and shaving doorhandles, gas filler cap, and probably drip rails using what I've learned. Also, I just bought a nice miller plasma cutter, what a fun toy. Managed to talk down the guy selling it (who bought at wholesale for $1200) to $450. |
10-08-2004, 12:12 AM | #21 |
Migs
I bought a harbor freight gasless mig, and I have has good results. The only problem is as people said it leaves a lot of slag that had to be ground off after you finish. I got a gasless because it was 125.00 on sale. There is a way to prevent the slag from sticking, and that is to brush a grease on the metal surrounding area to be welded. I have some pics of where I welded floor patches and I am very proud of the way my welder worked. But just keep in mind if you get a harbor freight gasless, PICK UP AN ANGLE GRINDER AND SOME GRINDING WHEELS TOO! But, all in all the grinding is not a big deal to do. it takes ten minutes.
10-08-2004, 12:19 AM | #22 |
Miller MM210 mig and Miller Syncrowave 180sd tig
10-08-2004, 01:31 AM | #23 |
the welder i use is called Fusor......sells for 44 bucks at API.
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon) WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt. |
10-08-2004, 01:51 AM | #24 |
Ive got An Old Air Products 250 amp AC Arc Welder that is hooked up and gets used It looks identical to an old school miller where there laying sideways and the crank and lead holes are on the front.
Ive got a relativley New Miller ThunderBolt 250 Amp Ac Arc Welder that sits in the store room cause the plug is different that what i have lol too lazy to make an adaptor or get a new plug and change it out And for wirefeeding I Have A Hobart Handler 135 Same components/Warranty as a millermatic 135 Its on flux now but when the 10# spool runs out im gonna get a cylinder and run non flux since I use it Indoors all the time ,, For delicate projects I have a century 100? Not really sure but it has eleventy five thousand voltage settings and is very good for thin metal/body work. |
10-08-2004, 02:21 AM | #25 |
Life, Be In It.....
I have been thinking about getting a welder and found a craftsmans. What do you think of this one.
http://www.sears.com/sr/javasr/produ...&bidsite=CRAFT
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
