10-07-2004, 06:39 PM | #1 |
73 front suspension on 72 blazer
Anyone know if a 73 front suspsension will fit on a 72 blazer. How much modification it would take and such.
10-07-2004, 11:19 PM | #2 |
If I'm not mistaken it works up to the late 70's to early mid 80's.
10-07-2004, 11:21 PM | #3 |
huh ???
The axle will work but the 73 up springs won't...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
10-09-2004, 06:25 PM | #4 |
If I recall correctly the next generation 2wd crossmember will bolt up minus one hole you have to drill, as far as 4wd stuff it is different on the front, the rear is the same but the front spring length is completely different
1st Gen Blazers Like em big and topless |
10-09-2004, 11:10 PM | #5 |
73 on a 72
My bad I was tired when I posted my question. What i am looking at doing is mounting a two wheel drive suspenson on my 72 4x4 blazer. I have a possibility of getting a 73 two wheel drive front suspension for cheap and am hoping it will fit.
