Life, Be In It.....
![]() Join Date: Oct 2003
Powder coated satin black, motor, trans, aluminum drive shaft, 12 bolt posi rear end. I just have to install the stainless brake lines, steel braided brake hoses, and the emergency brake cable. It has taken four years to get to this point, but I am happy with the way it has turned out. I owe a big thanks to my wife for letter me have this toy. I just dropped the cab off at the body shop to have the rust in the front window sill, floors and rockers fixed. Hopefully I will have it done before my six month old daughter graduates from high school.
I bought the stainless brake lines from classic industries. There are about six pieces, done anyone have a diagram or something on how the go together?
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
Wow
That looks nice. I really enjoy seeing someone take the time to do all that you have done. I am doing a 63 with a total frame off. I finished my frame a few months back and am in the process of finishing the bodywork on the cab and bed. I am going with a pontiac 400 though for the powerplant. But yeah that's awesome. MAN KEEP YOUR WIFE everyone cant do that!
Raphyel |
how expensive was the driveshaft?
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
Life, Be In It.....
Thanks for the compliments. I bought the drive shaft about 6 months ago, without digging through my stack of receipts, I thinks it was about $350-$390.
Still drivin' a Rat Rod
Looks great.Noting like a tubbed and narrowed ride for intimidation
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
Ebay Junky
what all did you powdercoat? how much was that? how do you like it?
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain.. 1983 Chevy c10 swb 2wd - possible 350tbi supercharged... |
Life, Be In It.....
I took apart the entire frame, front x-member, trans x-member, A-arms. These pieces were media blasted $300.00, them taken to the powder coater, $450.00. There are some pice of the pieces after they were blasted and before powder coating. I also had the front sway bar and fan powder coated.
Life, Be In It.....
I orginally painted the frame in my garge, but hated the way it looked. As for the powder coating, its beautiful. The guy that did the work put two coats on for no extra charge.
It has been sitting in my garage for about six months and was covered with dust. I took an old t-shirt, wiped the dust off and it looked like I just got it from the shop. I would recomend powder coating over painting.
Ebay Junky
is media blasting the same as sand blasting only that they use plastic instead of sand?
Life, Be In It.....
Yes, they also use walnut shell, and glass beads, as well as other material. I depends on what surface is being blastered and if you want to go to bare metal or not.
More Cowbell....
Hey Jugernot,
How about a closer shot if the bed floor. Is that diamond tread? Looks good from here. Did you bend it yourself?
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
looks good, what are you doing for the driveshaft to clear the the carrier bearing mount? it looks close.
#13 |
Life, Be In It.....
Yes the bed is diamond plate, I know someone who, had the equipment to bend and roll the aluminum.
There is a little over an inch around the drive shaft, so it is clear of the x-member.
#14 |
I also had my frame and entire underside powder coated. Instead of media blasting, they had a 4 part acid bath. It neutralized any rust, and cleaned everything off of the metal. Only problem with the dip is that it cleaned areas we can't see, or paint... I didn't think of that before I had it dipped...
Powdercoating rocks!! We used a nylon based coat that's really flexible. I had an extra piece coated just so I could play with it. I hit it with a hammer and the powder actually bunched up like it was rubber! I thought that was great! Everyone says that powder will chip, and fail after a few years. I don't think it will, and as jugernot says, it cleans up sooooo easy. I had 3 months dust and dirt and even some brake fluid and it wiped right off. I highly recommend it. I think my entire chassis (all parts) was $850.. Oh yeah, that included the inner fenders and the radiator support too. |
#15 |
Life, Be In It.....
Putter,
Here is a pic of the diamond plate floor. I have to make some adjustments and then have the pieces welded together.
#16 |
Shortbox wanna-be.
That is sweet as hell! I love the tubbed look. Any more detailed pics of the rear? I'm curious how you built the rear of the frame rails and such. What size of tires & rims?
Reid
1970 Chevy C20 Custom Camper 402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton) '71 Camaro SS 402/T400 resto '97 Z28 (11.41@127MPH) ![]() |
#17 |
Life, Be In It.....
The tires are 33x19.5x15, the rims are 15x10 I think. The back half of the frame is from Chirs Alliston.
#18 | |
Shortbox wanna-be.
How much did that kit set you back? Did it come with the rims/tires?
#19 |
Life, Be In It.....
When I bought the truck the previous owner had attached the chassis, rear end, and tire. But he did it wrong, so I bought new stuff and had to it redone. The only thing I bought was the frame rails and x-members. I did have the rear end rebuilt and switched to posi $650.
#20 |
Project 7dos
Whats the specs on the motor?
Sweet so far!! ![]()
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 |
#21 |
Life, Be In It.....
It is a 68 327, bores .30 over. It has forged 10.5:1 pistons, steel crank, pete jackson gear drive, edelbrock preformer rpm cam and intake, edelbrock 750cfm carb, crane roller rockers, weiland aluminum water pump. ceramic coated headers, 3 inch exhaust, flowmaster delta 40 mufflers. I am not sure how much horse power it will put out.
#22 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
That is gonna be a sweet truck when you get er done very nice chassis you have put together...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#23 |
![]() Join Date: Sep 2001
but what are you going to do for traction? :-)
#24 |
That does look great......but I'm with Lost Wages on the clearence issue.
An inch "static" is plenty, but after the bed/body is on it and the you hit a dip or bump..... You need to have you bump-stops set to keep the crossmember from hitting the driveshaft. At this point it should be pretty easy to support the frame and remove the shocks. Then you can drop the frame slowly and see what hits first. It's a lot cheaper to move bump-stops than replacing that shaft( and whatever else happens?) |
#25 |
its all about the +6 inches
Looking awsome.
