A.i.r
I have seen this term A.I.R. listed with our trucks. What is it. And I know its not air
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
Professional Grade
Its a set of pipes that go into your exhaust manifolds that inject air to cause the left over fuel that didn't combust in the cylinder to go off inside the exhaust manifold rather than dumping it straight out into the atmosphere
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Air Injection Reactor. Does what Russell said.
blood type; Retumbo
it was the factory's way of slapping a bandage on the lack of combustion effiency. the problem is that it overheats the manifolds. it does work as a temporary way to lower HCs for emission testing on hotrods going through emissions testing.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
blood type; Retumbo
man that sounds wierd. kind of like redundant repetition.
Too many parts per million? Increase the millions!
#7 | |
BINGO ! The answer to POLLUTION is DILUTION ! ![]() |
