Old 10-08-2004, 07:06 AM   #1
Bleach
this guy
Bleach's Avatar
Need help with bed removal on a fleet
Hey all, I am taking the bed apart to work on it some, then only to put it back together.
I have removed the tailgate, the floor of the bed (twas plywood.....first time I used an axe to work on a vehicle), and the bolts that hold the right fleetside onto the front plate of the bed that is next to the cab. On the very rear piece that sits under the tailgate, I removed those bolts and grinded off the tack weld that was holding it, but this SOB won't come off still. Is there some trick to this that I'm not doing? Anyone else ever had this problem?
Thanks a million!
Duct tape is like The Force. It has a light side, a dark side, and it holds the universe together.
Bleach is offline   Reply With Quote
Old 10-08-2004, 09:28 AM   #2
Huck
Huck's Avatar
You didn't mention the wheel wells----inner fender thingy. They are bolted to the floor and to the inner rear quarter. There is also a splash pan behind the wheel that is bolted to a cross member and the rear quarter that needs to come off. There may be two welds on that rear tailgate pillar, one on the side and one more on the front side. Good luck----Huck
Huck is offline   Reply With Quote
Old 10-08-2004, 10:30 AM   #3
Southpa
Southpa's Avatar
Yep, there are 2 welds and 3 bolts (facing rear) holding your rear bedside posts in. Have a close look at the inside edge, its been a while since I've been there, but there might be even more bolts.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
