Old 10-08-2004, 08:04 AM   #1
CPNE
Resident Curmudgeon
CPNE's Avatar
1/2 ton 2wd lower ball joints-any diff between 67-70 and 71/72?
I know tie rods and upper ball joints are different between drum and disk equipped trucks. I was wondering if the lowers were the same or not (same part#). Something tells me they may be but I need to confirm. Long story
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 10-08-2004, 08:11 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
71-72 lower ball joints are different for sure. Not for sure on the uppers. Inner and outer tie rods are also different!
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 10-08-2004, 08:12 AM   #3
rage'nrat638
rage'nrat638's Avatar
here's where i always go...
http://www.autozone.com
rage'nrat638 is offline   Reply With Quote
Old 10-08-2004, 02:17 PM   #4
68C15
blood type; Retumbo
68C15's Avatar
the diff. is in the stud where they go in the spindle. later ones are larger & longer. they will interchange on to older arms. thats what I did since I had rebuilt my 68 arms before going to discs from an 80 C10. they bolt right up on the uppers & press right in on the lowers.
Todd
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
