Old 10-08-2004, 01:26 PM   #1
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Question Assembly instructions for a new wood bed???
I have about everything I need to start fitting together my new SWB wood floor bed. I have heard that the Assembling Your New Bed "pamphlet" that Chevy Duty and others are selling for $3-$4 is not very worthy.
Are there any good online directions/instruction that anyone knows of? Heck, I'll even pay for good ones. I am sure I can figure it out, but it would go much smoother I'm sure with good instructions right in front of me.
I did find ECE's article, but they didn't go in to much detail on assembly.
Thanks!!
Bob
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 10-08-2004, 01:32 PM   #2
Mudder
Mudder's Avatar
Ya gotta start with the outside boards first. I did mine all by myself and had to start over a couple of times......
Mudder is offline   Reply With Quote
Old 10-08-2004, 02:17 PM   #3
Putter
More Cowbell....
Putter's Avatar
I started in the middle and worked my way out. Just don't tighten the bolts until all the wood is in place. I had to move a few 1/8" or so.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 10-08-2004, 02:31 PM   #4
glock35ipsc
Is there any assembly that can be started on the floor, then set the bed on the frame? In other words, do the cross sills attach directly to the bed sides, or does the wood go in-between?
Or does all the assembly have to be done on the frame?
Thanks for the help.
Bob
Old 10-08-2004, 02:48 PM   #5
HuggerCST
HuggerCST's Avatar
Hey Glock, just curious, are we talking about a fleet bed, or step?
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 10-08-2004, 04:21 PM   #6
cdowns
cdowns's Avatar
measure once and cut two maybe three times
Old 10-08-2004, 04:32 PM   #7
Putter
More Cowbell....
Putter's Avatar
My wood attached to the cross sills. The cross sills connect to the bed at the angle strips, through the outer board (at least on my stepside). Like if you looked from the top, the bolt goes through the angle strip, then the wood, then the cross sill, followed by the washer & nut.
Old 10-08-2004, 04:36 PM   #8
glock35ipsc
Guess I left that part out. It is fleetside. Every part to assemble the bed is new.
Bob
Old 10-08-2004, 05:09 PM   #9
john
member #16
john's Avatar
I put the wood in without the cross sills to check for fit and mark holes to be drilled. Make sure you have the cross sills in the right way that the braces in the fender well fasten to or they won't bolt up. Good luck John
john is offline   Reply With Quote
