Bleeding brakes
I Need to know of a good way to bleed brakes with one person. I have heard of using a vacuume pump but have never tried it.
Post Whore
![]() Join Date: Feb 2000
I just got done getting the miscellaneous parts to build a power bleeder - ought to be very handy!
http://www.arkansaspontiacs.org/tech...er%20story.htm http://www.bmw-m.net/TechProc/bleeder.htm
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Progress = 0%
Looks like a good idea. I'd suggest maybe using a much thicker piece of metal instead of the 1/8" that he used. A piece of 1/4" thick steel plate for example wouldn't flex when using a c-clamp like shown. Also, I'd use a rubber gasket instead of cork.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
Post Whore
Yep, those are the changes I am doing too.
After you apply the presser what do you do? Open the bleeders one at a time, do have to hold the pedal down.
#6 | |
The LuvShack Garage
![]() JJ FLIP 66, MY SPELLING SUCKS :p I NEED TO KNOW THIS ALSO ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Need spell check on here
67-72 parts collector,…
![]() Join Date: Nov 2002
I used a vacume pump on my blazer. It worked good. I still did it the old fashion way with two people, to check my work. No air at all. Works good when your steel line are completely empty. BUT,... I would still check them with two people. I worry too much!
1969 Custom 30 wrecker
I like the speed bleeders myself. I have them in most of my cars/trucks now. Just open the valve a bit and pump the pedal all you want. When done, close the valve and your done.
They have a check ball in them so fluid goes out but air cannot come back in on the upstroke. Available in the HELP section of most auto parts stores and also made by Russell company.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
Still drivin' a Rat Rod
Yup the speed bleeders is the only way to go,IMO.I have had no success bleeding brakes by myself without them.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
