Old 10-08-2004, 10:02 PM   #1
71swb4x4
71swb4x4's Avatar
S-10 weatherstrip on my 71 - pictures
Here are the pictures of the S-10 weatherstripping that I put on my 71 last week. The pictures are of the corner in the upper part of the door frame. It's the only part that doesn't look really stock but I think it looks fine. I would bet not many people would ever notice.
I bought this from GMC Paul's. It was on the same day I received it. Great stuff.
It pushed on, no glue. Installs real easy. The doors shut pretty hard now, but I am guessing it will get easier as I break in the weatherstripping.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 10-08-2004, 10:04 PM   #2
68C15
blood type; Retumbo
68C15's Avatar
it looks real good Shawn. to he77 with anyone who criticizes the inaccuracy! if you want to stop down sometime we can try to adjust your doors a little.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 10-08-2004, 10:07 PM   #3
mcmlxix
Collector of Projects
mcmlxix's Avatar
Why would you go with S10 seals for the door? Why not go with a replacemet 67-72 door seal?
Rich
1972 K5 Blazer CST Click HERE
Old 10-08-2004, 10:09 PM   #4
71swb4x4
71swb4x4's Avatar
My weatherstripping was so bad that you could barely hear the person next to you at highway speeds. I want to paint the truck next year, so I didn't want to glue new weatherstripping on just to rip it off next spring. So I thought I would try this and see how it worked out. I am very happy with it.
Old 10-08-2004, 10:13 PM   #5
70c10
67-72 Addict!
70c10's Avatar
Does the outer "soft" seal come attached already to the harder seal?. In other words is that seal one piece or 2 piece?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-08-2004, 10:15 PM   #6
71swb4x4
71swb4x4's Avatar
It is all one piece.
Old 10-08-2004, 10:19 PM   #7
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I'll try the used ones this weekend,since I already have them,and was gonna do it anyway,I'll be the guinea pig.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 10-08-2004, 10:21 PM   #8
krue
Designated A-hole!
krue's Avatar
HOw about throwing a copy of your first post over in FAQ? Good info to know.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 10-08-2004, 10:23 PM   #9
70c10
67-72 Addict!
70c10's Avatar
Thanks. The reason I asked that question, I saw some at the junkyard Saturday and when I touched the outside soft rubber it seperated from the inside hard rubber like it was made in 2 pieces. It seperated very cleanly.
Jim
Old 10-08-2004, 10:25 PM   #10
Brainchild
Brainchild's Avatar
Well it looks better than what's in my truck ATM.Is it juts stock S-10 weatherstrip? I mean if I pull the stripping off the S-10 in the salvage will it work? Provided it's in decent shape of course.
Is it a certain year S-10 that you use?
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
Old 10-08-2004, 10:25 PM   #11
1972C10
1972C10's Avatar
Were those new ? If so what was the cost?
Or what year S10 to look for the seals in? I may have to get some soon.
1972C10 is offline   Reply With Quote
Old 10-08-2004, 10:51 PM   #12
mcmlxix
mcmlxix's Avatar
Do you like the S-10 seal enough to put it back in after you paint? DO you think it fits well enough all the way around? And like everyone else was asking ... What year S-10 did you use?
Rich
Old 10-08-2004, 10:54 PM   #13
Brainchild
Brainchild's Avatar
Looks like it may be a good lowcost solution to me.I'm not doing a resto,I'm building a driver
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
Old 10-08-2004, 11:02 PM   #14
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
from what i saw on the GMCPAULS web site stock door seals were like 30 bucks but i think that those get glued on http://www.gmcpauls.com/Pickup.htm and the s-10 ones (82-93) were 50 bucks and just push on http://www.gmcpauls.com/rubber&weather_strip21.htm
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 10-08-2004, 11:16 PM   #15
incoma
incoma's Avatar
70C10 - I worked at a plant that made this type of seal, the plastic/rubber composite is actually extruded over a metal strip, and the foam rubber is inserted into the plastic or in some applications is glued to the extrusion. (I hope I remembered that correctly..) The extruded piece runs through some "breakers" that brake the metal strip up inside of the extrusion, the entire piece is then "molded" or bent to a specific application. We called this windlace and sold to all of the big 3. I think our machines spit this stuff out at 100-110 ft / minute depending upon the profile of the extrusion.
Sorry for the banter, I just got excited when I saw the pics and recognized the product. Has nothing to do with the thread..
incoma is offline   Reply With Quote
Old 10-08-2004, 11:27 PM   #16
Brainchild
Brainchild's Avatar
Well I was thinking about teh 84 S-10 I have in the junkyard,and how cool it would be just to clamp those babies right on there
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
Old 10-09-2004, 07:53 AM   #17
Jimbotronics
YA YA
Jimbotronics's Avatar
Hey 71SWB - thanks for the photos I think I'll give them S-10 strips a try as well. Not to change the subject, but what are your seats out of? 00-04 Silverado? They seem to sit pretty high, which I wouldn't mind, but can you still see out of the back glass ok thru the review mirror?
Jimbo
'72 SWB - 350 (frame-off resto in progress - donations accepted)
'04 Chevy Avalanche
'03 Cadillac CTS (wife's ride)
Restoration progress - http://67-72chevytrucks.com/vboard/s...d.php?t=335707
Jimbotronics is offline   Reply With Quote
Old 10-09-2004, 09:05 AM   #18
71swb4x4
71swb4x4's Avatar
Here is what I bought:
82-93 S10&15 Door Opening Weatherstrip
Part no: 1315118
1982-93 S10 & S15 Truck, Blazer Or Jimmy front or rear door opening weatherstrip attaches to cab and seals door to cab, sold in pairs. Lifetime Warranty
I think I will put it back on after I repaint. Of course that is a little ways a way so I may change my mind, but right now I am very, very pleased.
Old 10-09-2004, 10:11 AM   #19
71Chev
71Chev's Avatar
Actually I don't know if used seals off an S10 will still be long enough to reach around our doors. The S10 seals length is "cut to fit". And the seals I took off by Blazer when I discovered they would also work on my 71, were glued at the ends. Honestly I don't think you could get used seals that have already formed to a S10 door opening to re-form to the 67-72 door opening. It would be worth a try. Somebody grab some used ones and report back.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
Old 10-09-2004, 05:55 PM   #20
Maximum Overdrive
December 21, 2012
Looks good. Beware though that the hard seal on the inside tends to shrink when it gets hot in the cab. On my S-10 both rear corners of the inside weatherstrip shrunk in the summer heat.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 10-09-2004, 06:20 PM   #21
grebus1
grebus1's Avatar
Hey 71swb4x4, how about a couple pics (inside and out) of the upper rear corner of the seal? 71Chev had posted some of his in another post, but I'd like to see how yours turned out as well. I want to use these on my Burb, but I'm too chicken to spend the $$$ until I'm convinced they'll work well on the Burb's squared-off upper rear corner. Thanks.
'72 Chevy Suburban Custom Deluxe 10, 402/TH400
grebus1 is offline   Reply With Quote
Old 10-09-2004, 06:27 PM   #22
71swb4x4
71swb4x4's Avatar
I can get those, but my upper rear corner is rounded (pickup), and it worked perfectly.
Old 10-09-2004, 06:31 PM   #23
grebus1
grebus1's Avatar
That would be great...so far I haven't heard of anyone using them on a Burb, so the pickup's rounded corner is as close as I can come to seeing how the seals would work. Thanks again.
Old 10-09-2004, 06:45 PM   #24
71swb4x4
71swb4x4's Avatar
Here are the pics. Let me know if you need anything else.
Shawn
Old 10-09-2004, 07:49 PM   #25
68w/sbc406
68w/sbc406's Avatar
i think i remember reading that someone cut them and meitered the corner. but i dont think i would use them on a burb back door
