God Bless Mr. T
OK, here's the deal:
My driver's side light quit working on low beams, so I replaced the bulb with a halogen one and nothing changed, so I put the old bulb back in. My neighbor said that he thinks that it could be the dimmer switch. Can these things just go bad all the sudden? It was working for a while when I first got the truck, now died. Thanks for your time! James ![]()
Like a midget at a urinal...sometimes you must stay on your toes. |
Still drivin' a Rat Rod
Yeah they may not give a warning,and just die.Are both lights dead,or just one side?Usually a dimmer switch going bad causes the low,or high beams to quit or possibly both,but not right or left.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
its all about the +6 inches
brain child is right, there is no way for the dimmer switch to make just one light go bad.
Unplug the light, and look at the socket. if there is 30 years worth of that electrical grease, then try cleaning it out. Then check your power. Your ground is most likley good since the other light is still working, but you can clean it for GP. |
Got Light Emitting Diode?
try one of those voltage lights and stab it in the soket and see if it is getting power too
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
