10-08-2004, 10:36 PM | #1 |
67-72 Addict!
Need a passenger side door latch assembly
Anybody have one cheap?. I need one for a 70'. I need just the latch assembly in the door. How much shipped to 21236?. Thanks
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 10-09-2004 at 12:21 AM. |
10-09-2004, 06:20 AM | #2 |
Door Latch
Yeah, I do.
Do you need both the door part and the jamb pieces? or just what's in the door? |
10-09-2004, 08:03 AM | #3 |
New latch 49.00 shipping included used 20.00 shipping included.
Rest in Peace Ed. Thanks for all the good times. |
10-09-2004, 08:37 AM | #4 |
Door Latch
FYI, the door latch mech that is mounted within the door has a tendancy to have the center pivot pin break loose from the outer support housing which causes a problem. The latch roller gets cocked crooked. You can just spot weld this pin to the outer housing and the problem goes away.
If yours is totally shot, I have several that I believe are good---will send you one for the cost of shipping-----(re-you did the same of me a few years back on sway bar bckts!!!) returning the favor! Just send me you address via e-mail and I will get-er-done!!! |
10-09-2004, 12:10 PM | #5 |
67-72 Addict!
PM sent
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
10-11-2004, 10:25 AM | #6 |
67-72 Addict!
Is the PM function working?. I'm desperate here . I will pay right away with Paypal if somebody has one ready to ship.
10-11-2004, 10:20 PM | #7 |
67-72 Addict!
ttt
10-11-2004, 10:24 PM | #8 |
hey jim i got one in a door from a 69 i would have to yank it outta the door but u can have im never going to use it. it worked when i took the truck apart
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
10-11-2004, 10:33 PM | #9 |
67-72 Addict!
Thanks Jason. PM being sent.
10-11-2004, 10:34 PM | #10 |
it told me i couldnt pm you says ur box is full
10-11-2004, 10:41 PM | #11 |
67-72 Addict!
Not now
10-11-2004, 11:18 PM | #12 |
Jim, If you can't find any I should have some good used ones. I can check at the shop tomorrow.
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
10-12-2004, 07:36 AM | #13 |
67-72 Addict!
Thanks Bill, If I run into problems, I'll give you a shout!.
