10-09-2004, 01:58 AM | #1 |
I bought a spring compressor, but after messing with it a bit, I just throw it to the side and used the jack. Worked fine and I was able to put both sides in, all by myself, In around 45 mins.
Brian Pal 1971 Cheyenne 10 454/th400-Undergoing a full frame off resto. 1972 Chevy short/step 2wd, 350/th350 1983 M1009 CUCV Military K5 Blazer 1981 Dodge 1 ton 4x4 dually flatbed |
10-09-2004, 10:49 AM | #2 |
Do I need a Coil Commpressor tool for reassembly?
hey Guys n gals.... The wheels of progress seem to turn very slow for me but I now have my upper and lower TRW ball joints and control arm & bushing rebuild kits along with my upper and lower A arms all blasted and painted ready for reassembly. ECE 2.5" drop spindals have been painted and so has the Brake caliper. I have 2" Ground Force front coils which are beautifully powder coated in blue, to replace the stock coils for a 4.5" total drop in the front (back of truck is 4" drop). My question is: Do I need to buy some coil commpressors to make this reassembly safe and easy??? If so do I buy Exterior commpressors or Internal commpressors??? Any tips would be appreciated!!! I will snap some pics of all the paint work and the stance as soon as it goes back together.
Thanks....and happy Friday to ya!!!
Alex 1971 Lil' Red 350 SBC 700R4 |
10-09-2004, 10:57 AM | #3 |
i did not use a compression tool when i installed mine....I had the lower ball joint disconnected from the spindle, installed the spring into the housing, put a jack under the lower contol arm and jacked the lower contol arm up (making sure that the upper spring set in the cup properly) and then attached the lower ball joint to the spindle....was really easy.....
10-09-2004, 10:59 AM | #4 |
67 is sold
It can be done, but you can usually 'rent' compressors from local auto parts store for no charge.
10-09-2004, 11:10 AM | #5 |
its all about the +6 inches
There is no need for a compressor to remove or install the springs in these trucks.
In reality, with a dropped spring, you can pretty much just stick it in there nad swing the arm up. It'll hardly have any pressure on it at all. |
10-09-2004, 11:20 AM | #6 | |
67 is sold
10-09-2004, 11:34 AM | #7 |
Was it a 2 inch lowering spring?
I have removed hundreds of springs and installed just as many, never having a single problem. I'm willing to bet that if you look in any manual that is over 10 years old on these trucks...or any GM with simmilar front ends, they say nothing about a coil spring compresor. I may be wrong on that...but I'm willing to bet a punch in the gut. As long as the spring seats in the pocket, and you use a floor jack (for the stock sized spring) then there will be no issues. If you are still scared, then chain it up. Some of the lowering spings will actually be loose when the truck is lifted by the frame. It'll actually rattle in its pocket. |
10-09-2004, 11:36 AM | #8 |
67 is sold
It was the factory coil spring. I may not have had to, but I've heard one too many tales of springs causing harm...
Regarding the chain, that would have a negative effect on my powdercoated control arms |
10-09-2004, 11:56 AM | #9 |
I did it the same way dallas71 did and it was really no big deal
10-09-2004, 12:21 PM | #10 |
Merciless Butcher
I have a coil spring compressor but don't use it. If you really want to be safe, just run a heavy chain through the spring then through the hole in the center of the lower A arm and tie the chain together with a bolt. If it does come loose for some reason, it won't go anywhere.
Your Bought And Sold....I Got Your Soul! |
10-09-2004, 12:50 PM | #11 |
71 DELUX
I had to use coil spring compressors on my 1968 Mustang, and darn if those things are not just plain old evil!
With these trucks I've not yet found any reason to rent one, the coil springs come out and go back in fairly easier than in most vehicles. I am not saying that it is simple, it takes some maneuvering to get them seated properly into place. But once you've done it, you'll not worry about doing it again, at least not when installing drop springs.
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50 2003 FORD Escape 1998 Honda VTR1000 |
10-09-2004, 12:57 PM | #12 |
Keepin an eye out
My front springs are cut, jack up the front and they almost fall out.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
10-09-2004, 03:54 PM | #13 |
Thanks for the input and advise guys!!! I believe I will reassemble the front carefully with a jack and not worry too much about the coil springs. Thanks again!
