![]() Join Date: Apr 2000
700R4 change spedo to ecectric from cable
I have a 700R4 from a 87 2 wheel drive S10 Blazer in my 70 C/10 with a cable for the spedo. I want to change to an electric spedo. If I change the tail shaft housing with an electric pickup one and pull the plastic gear of the tail shaft do I just press on the new exciter and how do I know where it needs to be on the tail shft. I hope thats prity clear. I want to switch from a cable spedo to a electric spedo.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
If you don't want to change the tailshaft you may be able to get an adapter from www.jagsthatrun.com that will screw onto the mechanical part and send out an electronic signal.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
I thought of going that route but I think I can save some money with used parts from a U-Pull-It
Professional Grade
As far as positioning it is concerned, it just counts how many times the thing rotates, should send something like either 2 or 4 pulses out for every rotation of the gear. If it is a 4 pulse unit, you'll need a DRAC thinger that modifys the 4 pulse signal into a 2 pulse signal that the new speedometer can use. The only units that will have an electric speedometer and a 700r4 from the fullsize viewpoint of things will be the 88+ trucks (1 tons, suburbans and blazers included)
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
I have an 88 700R4 out of a 1/2 ton pickup that has electronic pickup. I want mechanical cable drive---want to trade speedo senders????????
computer illiterate
i also have a 700r4 out of a 88 firebird formula 350 with the electronic speedo if someone wants to trade for a cable set up
72 2wd blazer 72 swb 4x4 |
Huck I will let you know about a trade. Im might be geting one this week. When you pulled of the reluctor ring do you have 2 holes for the pin that holds the drive gear on the tail shaft?
Don't know as i havent pulled the thing apart yet. Do know that the 87 was mechanical and 88+ is electronic on trucks. Also have heard that the 87 and earlier had some design defects that were fixed with the 88 700R4's so keep that in mind.
