I'm back with 2nd truck!
If he doesn't want it and it's a truck shifter then I"ll buy it for the right price
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
On mine i only DRILLED a 1/2 hole for the cable If you take the adjustment nuts off the cable thats all you need
How i determined where i needed the hole was mounted my shifter where i wanted it and then Guestimated You can see how the cable mounts once the shifter is in your hands mine is held down with 1/4 bolts but i have use self tapping metal roof screws in the past. |
converting to floor shifter, auto
Im in the process of switching to buckets in the 85 and I would like to install a floor mounted auto shifter, maybe even a console. Im not quite sure how to go about doing this, like cutting the hole and where.
anyone got a how too? ![]()
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
Trucker.
I have a B&M mega shift I'll sell you that I know will fit in your truck since it's currently in my 83. Was used to move the truck on and off the trailer and that's it. You could ask Cam how he installed it.
![]() Pic: ![]() Last edited by Izzy; 10-09-2004 at 03:51 PM. |
Lemme know how much Iz
its really easy JB. the shifters are cable operated so you just have to drill a small hole in the floor for the cable to pass through. then it comes with a couple brackets to attach the cable linkage to the shift lever on the side of the tranny. nothing to it
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
#7 | |
