Old 10-08-2004, 10:15 PM   #1
PCV Valve maybe. Like you I can't remember exactly. but something like to much pressure blowing it back into air cleaner. I cant remmber if they said the PCV was bad or the brether was clogged and it was backing up through the PCV.
Old 10-08-2004, 11:53 PM   #2
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Worn rings, causing blowby and the lack of a baffle in the valve cover where the pcv is would do it.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 10-09-2004, 08:32 PM   #3
Russell
Professional Grade
Russell's Avatar
Oil in the oil filter housing?
Hey guys, just going over the 74 I bought here. As I expected, the cab is in sorry shape underneith, rocker panels have been replaced with slip ons, floor has some tin to replace where it was rotted out, cab supports are basically gone, etc etc etc No big worry as my 80's cab will be going on instead. But yeah, I popped off the air cleaner lid to take a look, and while the filter is real nice, the air cleaner has a ring of black motor oil inside of it... I remember reading about this sometime before, but I can't remember what causes it.
The truck sure starts and runs nice though, its got my 80 beat for sure there...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
