Old 10-08-2004, 10:26 PM   #1
kwmech
Dana 60 conversion
For the most part it is a bolt in swap. The most expensive thing is the single wheel hub/rotor assy, actually the hub itself. They are available thru Six States
Distibutors for a somewhat reasonable price. Everything else is interchangable.
OK how did my reply post get above his? DOOH!
Old 10-09-2004, 12:22 AM   #2
1969 GMC
1969 GMC's Avatar
you could also run some rims with crazy backspacing to narrow er a little.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 10-09-2004, 06:24 AM   #3
77gmcjoe
What do we get for $10?
77gmcjoe's Avatar
Would the hubs be the only parts I need to buy?
I checked Six States and they're about $400/pair.
Joe
1977 GMC K25 400/400/205
1989 Chevy Suburban R1500 350/700R4 (work beater)
1994 Chevy K3500 dually 454/4L80
1996 Corvette LT4 350/ZF 6 speed
2000 Bonneville SSEI Supercharged 3.8 Liter V6
1966 Chevelle 2 door sedan (Needs major repair )
77gmcjoe is offline   Reply With Quote
Old 10-09-2004, 08:49 PM   #4
77gmcjoe
77gmcjoe's Avatar
Dana 60 conversion
Has anyone here ever converted a Dana 60 front axle from a dually for use in a regular fleetside 3/4 ton?
I've been told it's an expen$ive ordeal.
Thanks,
Joe
Old 10-17-2004, 09:24 PM   #5
smokkey1
Land Beast
do you have an 14FF. if so you could convert you rear axle with dually hubs and leave the front alone and run some hummer rims.
90' GMC 1 Ton Suburban
smokkey1 is offline   Reply With Quote
Old 10-17-2004, 10:24 PM   #6
1FaastC10
1FaastC10's Avatar
im switching my dually D60 to SRW. i got lucky and found someone who had a set of SRW hubs for $150.
1FaastC10 is offline   Reply With Quote
