Z-Frame and lowering questions
What would it say when you Z-the frame? I know the basics, but have does that look?
I have a 4" drop rear (lowering hanger kit from Belltech). What can i do to make it even lower without air? Air is coming but not right now. I have seen 3" drop spindles for the front for around 300$ Anyone know of places that is cheaper`? Best Regards from Norway ![]()
http://www.moldestuket.com 1971 Mustang Mach-1 429 CJ-R 1973 Mustang Mach-1 289 1975/71 Pontiac Firebird Formula 400 1978 Chevrolet C-10 Fleetside Longbed Scottsdale 1980 Pontiac Phoenix |
The drop spindle price is average. They typically are priced between $250-350. You can cut 1 coil off for another 2-3" of drop depending on the amount of spring sag.
For the rear, a flip kit gets 5-6" of drop depending on the thickness of the spring pack. Add some drop shackles for 1-2" more. If you do the flip kit & shackles, you'll want/need to do a c-section.
where can i buy these C-Frame brackets?
67-72 parts collector,…
![]() Join Date: Nov 2002
I believe those are "Western Chassis" brand. You could also get your flip kit from them. Good stuff. You will have to re-install your stock hanger in the front and stock rear shackle for a 5-6 inch drop. Re-install the front hanger only and you will have a 7-8 inch drop,... (with the Bell tech shackle) Good luck,... lolife99.
I have a pair of those on my parts shelf & possibly will be selling them in the next couple of weeks.
www.loweredd.com
modmach1, I Z'd the front of my frame. I have some pictures on my website if you want to check it out. Ask me any questions if the pictures dont answer all your questions.
#7 | |
#8 | |
![]() ![]() That truck sits low !! How long time did you use?
www.loweredd.com
I worked on it after work every night for about a month. From 9 PM to usually 1 AM.
