Old 10-09-2004, 02:02 PM   #1
Guff
Guff's Avatar
Rearend Swap
Will a rearend from a 72 GMC with leaf springs work in place of the rearend in my 69 Chevy with coils? If not, can I swap just the axles? I found a 72 gmc that I'll be taking the disc brake setup off of and I want to have a 5 -lug rear as well.
-Guff
1969 C10 LWB, 350, 700R4, 3.73 gears
Guff is offline   Reply With Quote
Old 10-09-2004, 08:18 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
No, the leaf and coil spring rears won't interchange.
The axles won't swap into your 69 either, because the 69 rear is narrower than the 72 one is.
1970 year saw a change in widths of rears.
Old 10-09-2004, 09:30 PM   #3
NO LONGER DISTURBED KONCEPTZ
NO LONGER DISTURBED KONCEPTZ's Avatar
He's right but on the 70 rear end I belive it wasnt all of them. The ones with the narrower rear end was the ones build in late 70 when they started to get ready to build the 71 trucks.
NO LONGER DISTURBED KONCEPTZ is offline   Reply With Quote
Old 10-09-2004, 11:17 PM   #4
Tx Firefighter
Yes, if you run into a 70 model, you have to measure to see if it's the wide or narrow rear. After 70 though, they were all wide.
Old 10-16-2004, 06:37 PM   #5
purple gas
I could be wrong (I often am) but wasn't there a camper special option available with a wider track in the early years?
purple gas is offline   Reply With Quote
Old 10-16-2004, 11:01 PM   #6
botboy
You could do the swap but it would require removing and re-welding on spring perches from one rear end to the other, and if you don't know your welding skills well this could be a matter of life and death, so probably want to leave that to a professional...
botboy is offline   Reply With Quote
