Engine ID help
Would anyone know what this engine might have came out off?
I bought if from a salvage and the owner didn´t have a clue. Casting# 3970014, it is a 2 bolt main. Stamped code: T 1025 CMJ Date code: J11 74 Head casting# 3998991 1;st pic, front engine mount bracket, the block does not have the side of block engine mounts. 2;nd pic, vaccum to distributor setup? 3;rd pic, flywheel is about 16" dia and the clutch is about 13" dia and it is a three finger type and the rear of the engine have an "adapter plate" to make it take a bigger bellhousing. Would appreciate if anyone could help. I´m curious, would be nice to know. Last edited by 68 50th; 10-09-2004 at 05:43 PM. |
68-79 ,350 cid ,145 hp chevelle or impala most likley. hope its of help to you
gm's are #1 1967 chevrolet short step 1988 chev 4x4 1/2 ton 1989 gmc 1/2 ton 1991 chev 1/2 ton 4x4 1993 Jeep grand cherokee 4x4 And yes a 94 Ford Mustang. ![]() ![]() |
Drive it like U stole it
sept 11 1974, 350 . out of a c60 or some sort of a medium duty truck. That would be a good one to build!!!!!!
71 custom 10 swb 72 nova ss 72 nova custom 87 s10 96 burb 94 camry 53 5 window 3100 |
http://www.nastyz28.com/spmenu.html
this is a good link for suffix code
also CHEVYMANIA.COM and MORTEC.INC. there are lots of places on the net that have good resorces for this kind of info.
Thank you guys.
It was the different motor mount bracket, clutch setup and some other things that made me confused, it make sence if engine come from a C60 truck or similar. Thanks. |
