Old 10-09-2004, 09:07 PM   #1
from_the_edge
SPARK PLUG CHANGE & NOW NO POWER
Please help me with this problem I am having I changed the oil, cap, rotor and plugs on my truck today and it started up just fine. So I put the air cleaner back on to take it for a spin and soon as I put it into gear there was no power it would go but really sluggish. I had this happen to me before on an older truck and the coil wasn't strong enough to power the new components. That was on an 86 4.3. This truck is an 91 c1500 with a 5.7
Please any coments at all.
thanks in advance
71 Chevy 1/2 ton work in progress
96 Sunfire
03 Montana
the truck is a mess but good times ahead
from_the_edge is offline   Reply With Quote
Old 10-10-2004, 03:17 PM   #2
1986Silverado
What I drive
1986Silverado's Avatar
May have gotton your wires swapped around and on the wrong terminals on the cap.........just a thought
1986 Chevy Crew Cab Dually(Choo-Choo Conversion)
2006 Chevy Equinox
1986Silverado is offline   Reply With Quote
Old 10-11-2004, 11:02 AM   #3
99-2door
99-2door's Avatar
Maybe you moved the distributor while changing the cap and rotor. Swapped plug wires? Wrong plug gap? Wrong plugs?
95 K3500 SRW 5.7L Vortec 4L80e 4.10 G80
2001 GMC C3 6.0 AWD, Volant, 3/5 drop TBSS intake, HP tuners, pullies, 05 efans, 05 front brakes, etc.
2003 Tahoe Z71 Silverado front clip
99-2door is offline   Reply With Quote
Old 10-22-2004, 11:52 AM   #4
tx_fireman1525
tx_fireman1525's Avatar
Did ya check the plug gaps?
]'76 K10 Short Step WORK IN PROGRESS
'81 C10 Longbed, 250/SM465
'93 Dodge W-250 X-Cab, Cummins NV4500/NP241, D60 front, D70 rear
'05 Yamaha Grizzly 660 4x4
Southern Bowties Member
tx_fireman1525 is offline   Reply With Quote
Old 10-28-2004, 08:19 PM   #5
bowhunter
Was it sluggish before you changed these items? Were you just doing routine maintenance?
bowhunter is offline   Reply With Quote
Old 10-29-2004, 06:19 PM   #6
GM-TECH
If all the above doesn't fix your problem, it is possible that the plugs are not the right ones ( sometimes when crossing brands over this happens) or maybe the gap is not correct.(box dropped tighting gap, etc..)
GM-TECH is offline   Reply With Quote
