What year van for tilt steering conversion?
I found one in a '78 van, but I can't remember what year works.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
its all about the +6 inches
72 - early 82.
tilt tips
I had a 67 gm, 3 on the tree. ( one long shaft, no U-joint, and not colapsable,, safe eh?) got a column from a 77 van. I needed a lower short shaft with a U-joint & coupler, it seems automatic trucks came with them( many years will fit, but check your sizes, there's a few varieties). when I put it together the assembly was about 4 inches longer than the original shaft. ( not sure if all van column/ lower shafts are like that) otherwise, it fits perfect, just watch the nibs in the dash that line up with notches in the column.. Oh by the way the truck is undrivable this way, unless you take the seat out. 4 inches is a lot, so I have to get the lower shaft shortend. there may be combinations that fit perfect, but I'm tired of looking.. SO, don't wreck your old parts when you first put it together!! Hope this helps
purple gas
You need to collapse your lower shaft. Drill out the nylon pin and collapse the shaft with a hammer. Its the shaft that was between your old column and the steering box.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
the 67 and 68 does need the shaft from a 69 - 72, the collapsable shaft started in 68.
I have never had to drill out the nylon...just hit the collapsable shaft on the shop floor. Worked every single time I've done it. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Purple Gas, here's a picture.
You need to shorten this shaft. It's meant to collapse. Just drill the nylon rivets and hammer the shaft 4 inches shorter. Then, you can bolt your column in like is was intended and get your clearance between you and the steering wheel back. The picture is my truck. I have a motorhome column, but I have done several van and motorhome column swaps into these trucks. They're the same fitment.
Damn, you guys are good,, and fast! Thanks for the tips on shortening the shaft. Anyone got any tips on how womens minds work?
#8 | |
Actually, i used to know a guy who figured out wmen...he died laughing.
#10 | |
Got Light Emitting Diode?
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
Lovin' Life in Miss.!
Tx, does any other part of the column collapse? Thought that room was to keep someone from being impaled. Or am I missing something?
The truck... you hear that? No really, you did hear that?!!! |
No, that's where the collapse is built in.
There is still more room to collapse even after shortening it, but technically, you're right, there is now less collapse built into the column for safety.
#13 |
OK. That is utilizing the van shaft? Can you utilize another shaft with the correct lenth built in? What year group/model? Thanks.
#14 |
No, that's the truck shaft that everyone uses.
The van intermediate shaft is way short. |
