Here are a few pictures of my new old truck. As you can see from the pics, from a distance the old girl looks pretty good.
![]() ![]() ![]() Both rear cab corners are rusted through. ![]() Here you can see the rust through above the windshield. ![]() ![]() ![]() ![]() Yep, that's green grass you see through that big hole. ![]()
![]() 2012 Silverado LT 1500, 5.3, 6 speed auto '86 SWB C-10 Silverado Last edited by crawdad; 10-10-2004 at 02:31 AM. |
Rust
The windshield frame would do it for me, I'd try to find another cab.
Everything else is certainly repairable but to what extent. I started on a cab that looked like it only needed a passenger's side rocker but after sand-blasting there was more... ![]() Good luck. ![]() |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
If that's a daily driver some of those repair's are gonna be labor intensive.. Do you have the skill's and tool's to do that kind of work,or will you have to farm it out. If the work get's farmed out you lknow it's gonna cost you some coin,but if you can do it yourself then those repair's are not that hard to do...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
If you can weld you can fix it, all the patch panels are available including the inner roof panel,lower inner door panels etc also we have rust free roofs in stock, finding a better cab would be my choice but yours is fixable in my opinion.
Rest in Peace Ed. Thanks for all the good times. |
It's not a daily driver. I've got it parked and work on it whenever I can get time. I thought I would buy a welder and try to tackle the repairs myself. Maybe that's ambitious thinking, I don't know. If I screw it up bad, I could always junk it and try to find another cab.
![]() 2012 Silverado LT 1500, 5.3, 6 speed auto '86 SWB C-10 Silverado |
