Old 10-10-2004, 11:54 AM   #1
BIGPIMP
PIMPING RIDES
BIGPIMP's Avatar
Rear End
i have a 64 c/c10 step and i have successfully changed the front over to disc .my question is the rear end . how hard is it to put a different rear end ,because the front parts are from a 1985 c/10 . i bought the spindles from a junk yard and tie rods and ball joint are from orielly's . i still have to get master cyclinder ,booster ,and proportion valve which i will get from the same 85 . will the 85 rear end fit without a lot of mods . think i will stay with manuel steering right now . no big problem there .
1964 CHEVY 1/2 C/10 FLEET
1981 CHEVY 1/2 C/10 FLEET
1995 DODGE 1500 V6 FLEET
EAST
http://www.flickr.com/photos/bigasspimp/?saved=1
BIGPIMP is offline   Reply With Quote
Old 10-10-2004, 07:35 PM   #2
zenish
a 1965-72 will bolt in except for the panard bar.you could use the later panard bar if you change the frame bracket. www.earlyclassic.com sells conversion kits for later rearends.
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 10-10-2004, 10:19 PM   #3
65StreetCruiser
It Is What It Is
65StreetCruiser's Avatar
BIGPIMP, If you only want to convert to 5 lug for the rearend Early Classics also offer the correct length axles for your rearend in 5 lug. Check their website.
65StreetCruiser is offline   Reply With Quote
Old 10-24-2004, 06:25 PM   #4
ChevyStepside
those early classic axles will set you back about $300 each if not more.. If you want 5 lug like up front then a rearend out of a 71or 72 is what you really want.. bolt right in...
ChevyStepside is offline   Reply With Quote
Old 10-24-2004, 07:57 PM   #5
BIGPIMP
PIMPING RIDES
BIGPIMP's Avatar
Yeah
thanx that's more my style
EAST
