Old 10-10-2004, 01:43 PM   #1
Stingray42
Woot.
Stingray42's Avatar
EGR Valve
Emissions are a big PITA. I just put a cat on it, and now need to put a new EGR on her. thing is its 110 buck CAD!!! I only spent 400 on the whole truck! Now, what do i do here? should I be able to get one cheaper? I dont think I'm gonan buy any more vehicles that need emissions stuff unless there are mid 90s and newer! Sniffer test just costs more...
Clarkson
96 Chevy RCLB 4.3 2WD
Stingray42 is offline   Reply With Quote
Old 10-10-2004, 04:53 PM   #2
Russell
Professional Grade
Russell's Avatar
What year is it and what part do you need? I can see if there is something in the local wrecking yard here...
It must suck to have emissions testings over there.. We don't have them here, yet. I'm smogging my TPI so that I won't be in any trouble when emissions testings make their way out here to Alberta
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 10-10-2004, 07:40 PM   #3
Grim Reaper
What makes you so sure the EGR is bad? Clogged up passages from running too rich is actually more common then a "Bad" EGR.
Many of those EGRs are a Bleed off style and you cannot test them with a hand vac pump. To verify if its working stick your finger against the diaphram and rev the engine up to about 2500RPM and hold it and see if you feel it open. If the holes are to small in the underside of the diaphram housing you can put a stick in the hole against the diaphram and feel the stick move when it opens. If the holes in the underside are large (most are) you can manual open the diaphram with your fingers. At idle if you open it it should cause the idle to go to hell. Its hot might need gloves.
If no change then its proably clogged up ports. Peice of coat hanger and a shop vac WITH THE CARB OFF THE ENGINE (you can suck gas up if the carb is still on and make a large boom and Darwin yourself) usualy does the trick. Will have to pull the carb off to clean the port in the plennum divider. Thats where my 79 plugged up.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 10-10-2004, 09:21 PM   #4
Stingray42
Woot.
Stingray42's Avatar
shoulda specified..... lol.
There is no EGR on the truck at the moment. it has been ripped off (except for the base) and has no lines....
I bad, sorry lol.
I may hit the scrap yards, may coem across something!
Also, what are some good tricks to make one of these trucks pass the sniffer test?
Clarkson
Old 10-10-2004, 11:51 PM   #5
SanitysBane
10 dollar bribe...
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 10-11-2004, 01:38 AM   #6
1FaastC10
1FaastC10's Avatar
or find someone who has an 86 that they stripped said emissions parts off of... wouldnt know anyone here who has done that....
shoot me a pm.
1FaastC10 is offline   Reply With Quote
Old 10-11-2004, 05:25 PM   #7
Stingray42
Woot.
Stingray42's Avatar
Originally Posted by SanitysBane
10 dollar bribe...
for a $5000 fine? doesnt work anymore
PM sent 1FaastC10
Clarkson
Old 10-11-2004, 06:33 PM   #8
grayw0lf
They are supposed to start emissions testing here in '06 & I hate it to death. I think my '70 is grandfathered in (I would hope so, even California gives you that), but I'm gonna have to go out a buy a catalytic converter for my S-10.
You know, with today's modern technologies, we could probably bump up fuel mileage at least a good 25% if we got rid of all this emissions crap. Catch 22.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 10-11-2004, 06:36 PM   #9
cliffsta
Stepsides RULE
cliffsta's Avatar
Thank you. You just made my point. If im not mistaken, we will run outta petroleum in this century. So why kill gas mileage with cats and emissions when we can clean the air? We can't exactly make petroleum
ALTHOUGH every internal combustion engine can easily be converted to burn hydrogen, which is the answer to the fossil feul probelm.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 10-11-2004, 08:16 PM   #10
Stingray42
Woot.
Stingray42's Avatar
really?
cool.
Good point on the gas burnin stuff there
Clarkson
