Old 10-10-2004, 05:23 PM   #1
Alexis
Member since 2000
Alexis's Avatar
Question Good welds or bad?
I never really had someone tell me if my welds were good or bad. If i'm doing it right or wrong. Or still need to mess with the settings. So I thought I'd show the board and see what insight I could get. I've been messing with the settings and I'm running the line pretty hot and feel the wire speed is good but I might slow it down a bit I don't get any poping when welding. I run my argon at "30".
Alexis is offline   Reply With Quote
Old 10-10-2004, 05:31 PM   #2
ebfabman
Alex, looks real good from here. Can you get a closer pic?
ebfabman is offline   Reply With Quote
Old 10-10-2004, 05:39 PM   #3
Alexis
Member since 2000
Alexis's Avatar
heres a closer shot
Old 10-10-2004, 05:46 PM   #4
ebfabman
Yes, those are good welds. Are you going to dress them down or just clean up and prep for refinish?
Old 10-10-2004, 05:50 PM   #5
Alexis
Member since 2000
Alexis's Avatar
since the windshield gromet crovers this section and much more I'm not to much into detail here but do put in work . Plus the body shop will get down to detail everything.
Heres a link on what this project(upper windshield) consisted off. check it out and any input would be nice.
http://207.44.196.117/vboard/showthread.php3?t=122912
Old 10-10-2004, 05:53 PM   #6
ebfabman
Looks like a real solid repair. Have you considered coating the insides of the channels?
Old 10-10-2004, 05:58 PM   #7
Alexis
Member since 2000
Alexis's Avatar
Yeah, I am, once I do the the other side of the winshield which should provide a better clearing to spary it down inside. The good thing which I was amazed about was you could see fresh metal inside, which was a sign of relief to me.
Old 10-10-2004, 06:05 PM   #8
ebfabman
Yeah, Fresh metal is always a good sign! Keep up the excellent work. When you're finished, I'd like to check it out in person
Old 10-10-2004, 07:29 PM   #9
Blue Beard
Blue Beard's Avatar
What are you using for a welder?
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 10-10-2004, 08:15 PM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I'd use more heat and less wire. I like my welds penetrated very deep so not much is above surface level.
Old 10-10-2004, 09:21 PM   #11
Alexis
Member since 2000
Alexis's Avatar
Millermatic 135 , Mig Welder with Argon
TXfirefighter. I turned up the heat a little. I just don't want to burn through the metal. Slowly but surely I'm getting the hang of this welder.
Old 10-10-2004, 09:27 PM   #12
Tx Firefighter
I'm kind of semi serious about my welding. I'm actually starting a little welding and fence business right now.
Anyway, I weld real aggresively. I hit it fast with a lot of heat, right on the ragged edge of meltdown. Of course, each weld demands a different approach, but that area is very strong and not likely to warp, so you have more cushion under you there.
Sheetmetal in a big panel of course requires as little heat as possible and quick work.
By the way, you have the finest 110V Mig welder made.
Old 10-10-2004, 09:33 PM   #13
ebfabman
Excellent choice in a welder. The way to tell about penetration is the color and amount of discoloration on either side of the weld. You are getting good penetration without a lot of heat and because you're are using a faster wire speed, you have plenty of material to remove and make a smooth joint.
Old 10-10-2004, 10:37 PM   #14
Russell
Professional Grade
Russell's Avatar
Hmm, I have a Millermatic 135 with Blueshield 8 gas, and I cannot for the life of me get a good weld out of the thing, it just seems to have no balls... Maybe I am just too used to stick welding, but I either burn through, or I just build mountains with the thing... Using a thinner wire (.23 I do believe) BTW
Looking extremely good Alexis, I can only hope that my attempt at bodywork turns out as nice...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 10-11-2004, 04:38 PM   #15
67cst
i love summertime
67cst's Avatar
alex, once again you amaze me, it took me a year at trade school to get those kind of results, your self taught from what i understand, thats pretty impressive bud
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 10-11-2004, 06:16 PM   #16
Alexis
Member since 2000
Alexis's Avatar
Most of my credit go's to this board. I just try to run with what the "VETS" say what to do and run off the DVD i got and photo's posted here. So thank guys.
Old 10-11-2004, 09:17 PM   #17
lock
Insert funny comment.
lock's Avatar
Nice work. Whats your techniqe to get those nice welds? Im learning myself.
- Mark
-My Build Thread...
-68 C10, LT1 - Undergoing Frame off resto
-86 IROC-Z T72 turbo 355, M6
-70 Camaro
http://www.iroc-ss.com
lock is offline   Reply With Quote
Old 10-11-2004, 11:01 PM   #18
rusted75 half ton
More trusty Less rusty
rusted75 half ton's Avatar
Hello,mr.ebfabman,saw your website sent you a PM. Thanks,
rusted75 half ton is offline   Reply With Quote
