Old 10-10-2004, 08:54 PM   #1
nu2-72
Wanted, pics of 4x4's w/sway bar
I am needing some pics of 4x4's with front sway bars and it would really be nice if you have a 4" lift as well.
Show me how you did it.
I have a 73 up 1 1/4" bar to put on. I was told that the crossmember/brace was a direct bolt in. Not so. Even if it was I have the extra lift to cover. Spacers would have worked but it looks like I will be building a special cross mount.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 10-10-2004, 10:48 PM   #2
chevy71super
I put a sway bar on my 71 with a 2.5" lift. Should be about the same for a 4" lift. You need to switch the mounts from the 73, use the left frame mount on the right side or your truck and the right frame mount on the left side of your truck. Post your e-mail address and I will send you some pictures.
chevy71super is offline   Reply With Quote
Old 10-11-2004, 12:43 AM   #3
The Dude
this is mine (1975) with a 10in superlift swamp runner kit. i ordered the kit with every option so i came with the spacer to put between the frame mounting points and thre swaybar. my truck originally came the bar you can kinda see how it is set up in this pic..
The Dude is offline   Reply With Quote
