Old 10-11-2004, 01:18 AM   #1
1FaastC10
1FaastC10's Avatar
68 C20 Longhorn questions
my buddy called me up on Friday to tell me about the new toy that he traded his old dirtbike for. he told me it was a 3/4 ton 2wd, with a blown 327 in it (broken, not supercharged). on the phone he told me there was something funny about it, he said the bed looked like someone had added a section to it. i went over to take a look at it today, and sure enough, its a Longhorn, and a damn solid one at that! the cab needs some attention, but the bed is very solid, despite some body damage (big dents in the lower bedsides, but no creases, should be easy to pull out.) overall, its in good condition for this area.
a couple of the questions that came up are regarding the trans and the front suspension. he will be getting a mid 70s 3/4 ton truck with a big block and a 465 in it. his plans are to use the big block, will the 465 fit in the place of the stock trans? it is a 3 speed floor shift unit, and appears to be stock.
will the front suspension from the 3/4 ton bolt in place of the stock suspension? the donor truck has all good suspension, and disc brakes up front. i know the 73-87 1/2 ton units will bolt right in to a 67-72 no problems, are the 3/4s the same? also, what rear should be in this truck? how strong is it? he is planning on putting it together for a tow rig.
1FaastC10 is offline   Reply With Quote
Old 10-11-2004, 01:31 AM   #2
1969 GMC
1969 GMC's Avatar
thats a good find, '68 was the first and lowest production year for the Longhorns. For specific Longhorn info, check out the link in Longhornman's sig. The 3 speed floor shift isn't original, the 3 speeds were column shift only, so some sort of conversion kit was installed. The 465 will bolt up but it might hit the floor of the cab. The rear axle should be an Eaton H052, they are strong. Comparable in size to the 14 bolt but it has a dropout third member and coarse spline axleshafts. Bearings are expensive, but it may have an OEM detroit locker (called a no-spin on the option sheet).
oh and I have to ask, is it painted gold and white? slim chance it may be a 50th anniversary edition.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 10-11-2004, 01:59 AM   #3
1FaastC10
1FaastC10's Avatar
its all white, but doubtful that its factory. you say the 3 speed isnt factory floor shift? there isnt any form of shifter on the column. is it possible that its actually a 420? and not just a 3 speed?
Old 10-11-2004, 02:27 AM   #4
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
I was under the impression 3 speeds on the floor were available, although not as common as 4 speed op??
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 10-11-2004, 08:20 AM   #5
toms68cst
toms68cst's Avatar
I've never heard of a 3 speed floor shift in any of our series of trucks.
Are you sure it's not a 4 speed all ready?
What's listed on the glovebox?
When are you going to take pictures and post them on the site???
Is the 327 rebuildable?
Is it a Custom or CST?
Am I full of questions today??
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 10-11-2004, 09:47 AM   #6
1969 GMC
1969 GMC's Avatar
'68 was the first year of the 465, but the 420 is possible. either way, the "4 speed transmission" would be on the glovebox label. my guess is that its a factory 4 speed but the p/o called it a 3 speed because it only has 3 normally useable gears.
1969 GMC K2500
1996 Honda Accord
Old 10-11-2004, 05:45 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Sweet find....longhorns rock!
Why isn't your friend introducing him self to us?
Old 10-11-2004, 06:54 PM   #8
1FaastC10
1FaastC10's Avatar
its definitely not a 465, looks nothing like the 3 465s i have in the garage anyways. unfortunately the original 327 is long gone, and was replaced with a '64 283 which is trash due to the 1 and 2 rods deciding that they no longer wanted to be straight.
not sure if its CST or Custom, nor what is listed in the glovebox. i can try to make it up there this week to get some pics of it. and he hasnt introduced himself because, well, he's kinda computer illiterate and doesnt like to mess with them unless he has to.
Old 10-11-2004, 07:03 PM   #9
Pilgrim
Tell him not to worry. We are all computer illiterate. We just don't know any better...
Bob
68 C20 Camper Special
Pilgrim is offline   Reply With Quote
Old 10-11-2004, 10:42 PM   #10
Longhorn Man
And tell him now he has to!
Old 10-11-2004, 10:44 PM   #11
1969 GMC
1969 GMC's Avatar
does the trans have shift rods coming out the side, basically meaning is it a toploader? if its a toploader and isnt a 465, it could be a 420 or a NP435. if its the 435, it will have an aluminum cover.
1969 GMC K2500
1996 Honda Accord
Old 10-12-2004, 05:23 PM   #12
1FaastC10
1FaastC10's Avatar
no shift rods that i saw anyways. anybody have any input on the front suspension and converting to disc brakes?
Old 10-12-2004, 08:28 PM   #13
crazy longhorn
Fabricate till you "puke"
I cant help with #, options, ect.....but I smell a HOTROD! A 133" wb chev tends to go pretty straight.....if you start spinnin it, trust me ...you will have your hands full! crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 10-12-2004, 10:14 PM   #14
1FaastC10
1FaastC10's Avatar
also tends to not hook up due to a lack or weight transfer. for hotrods, the shorter the better.
Old 10-12-2004, 11:00 PM   #15
rage'nrat638
rage'nrat638's Avatar
TELL YOUR BUDDY TO SPEAK UP.....
OR GO HOME!!!!!!!!
NO SLUT'S HERE !!!!!!
rage'nrat638 is offline   Reply With Quote
Old 10-13-2004, 12:06 AM   #16
1FaastC10
1FaastC10's Avatar
HEY! you drive an S10, who asked for your opinion i would tell him to speak up, but he has no computer, and is computer illiterate anyways.
Old 10-13-2004, 11:11 AM   #17
crazy longhorn
yes, the longer trucks do pose a challenge in the traction department! The big thing is to move as much weight rearward as possible, & remove any unneeded nose weight my longhorn runs a 3 1/2" eng setback, rear fuel cell, battery under the box, no heat or air,no inner front tubs, Jazz buckets, ect. For a leaf spring truck , withan eaton posi & traction bars, she hooks up pretty good on street tires
tough, but not impossible....crazyL
Old 10-13-2004, 11:33 AM   #18
Baradium
Binder Rep
Baradium's Avatar
Sounds nice!
There is/was a used car place around here that had a '69 GMC longhorn. That truck originally had the V-6 in it, has some type of car v8 in it now, auto tranny. They've moved all their cars, I'm assuming they changed locations, but I don't know where too. Not the prettiest truck, however. Hopefully someone will pick it up and give it some help.
There's another down in GA that needs the help even more. It hasn't moved in so long that I had to knock a small tree down to get one of the doors open.
Congrats to your friend!
Contrary to most other people, I'd say try to make it into a killer tow rig! Longer the wheelbase, the better your tow experience. Of course... after a point, it's like a bus...
Baradium is offline   Reply With Quote
Old 10-14-2004, 12:33 AM   #19
1FaastC10
1FaastC10's Avatar
the plan is to make it into a tow rig. hence the big block and 465 going into it. still, nobody has replied to the suspension question. how do you convert it to disc brakes while still retaining the 8 lugs?
Old 10-14-2004, 05:51 AM   #20
Longhorn Man
take the front end parts off of a 71 and up 3/4 ton or one tn truck.
You'll also need the wheels since they went ti 9/16 inch wheel studs n 71 verses the 1/2 inch wheel stud you have on it now.
Old 10-14-2004, 09:24 AM   #21
Baradium
Binder Rep
Baradium's Avatar
And you'll need to upgrade the back to 9/16" studs too...
It's not really too bad to do.
Old 10-14-2004, 04:57 PM   #22
1FaastC10
1FaastC10's Avatar
just found out that its actually a 1 ton, not a 3/4 like we previously though. he got the title today, and it says C30 right on it. does that change things at all?
Old 10-14-2004, 05:45 PM   #23
Longhorn Man
the rear will have some internal chainges...the registration will be a whole lot more...but on the Longhorns...they are pretty much the same.
