Old 10-11-2004, 08:03 AM   #1
greg0380
Truck hops when pulling a heavy load
Thought I would try posting here, I've got an 85 1/2 ton lwb, 305, SM465, 10 bolt 2:37 gears. I was pulling the boat home (probably 6800 lbs with trailer), and every time I tried to move from a stop, the whole truck would hop around until I got moving. I was talking to a guy at the boat ramp who noticed it and said something about the rear end. I was wondering if there is something I could do to help this.
greg0380 is offline   Reply With Quote
Old 10-11-2004, 08:42 AM   #2
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Is it like clutch chatter,or something different? Could be the clutch getting weak.2.37 gears aren't goingto help much in the towing field either.
I'm thinking the clutch is needing changed
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 10-11-2004, 10:35 AM   #3
greg0380
I don't think it's clutch chatter, it did the same thing when I replaced the clutch a couple of years ago. I know the 2:73 gears don't help, but I thought the granny gear of 6.55:1 would compensate to get me moving. It's hard to describe the "hop", kind of like the back end bounces up and down. I also notice it does this in reverse even when not towing.
Old 10-11-2004, 11:06 AM   #4
64fleetside
Check u-joints & slip yokes for slack/binding. Brian
64fleetside is offline   Reply With Quote
Old 10-11-2004, 04:18 PM   #5
LONGHAIR
I would look at the motor mounts and the trans mount too...
LONGHAIR is offline   Reply With Quote
