Old 10-11-2004, 11:03 AM   #1
cgrossl
A/C Compressor Kicking on When it Shouldn't
The A/C in my 85 works pretty good. From what I can tell, it is all original and has never been messed with. The only problem is, that when I have the dash switch on vent, the A/C compressor still comes on. I took the climate control panel out and I noticed that there was a rotary switch that controls this stuff. I was hoping that there was an adjustment, but I couldn't find one. Do I just need to replace the switch, or, is there an adjustment that isn't readily apparent?
cgrossl is offline   Reply With Quote
Old 10-11-2004, 12:35 PM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Mine just started doing that a couple of days ago. I'm assuming that the switch is bad, but I am interested in seeing what other's experience have been.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 10-11-2004, 01:30 PM   #3
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
You may try replacing/wiggling the switch that in on the a/c condensor under the hood (It's the aluminum cylinder on the passenger side of the truck by the firewall). There should be two wires feeding to it. This switch kicks the compressor on/off depending on your freon level, but you may have a bad switch. They range from $15-20 and it's an easy install. Good luck.....
CLASSIC87' is offline   Reply With Quote
Old 10-11-2004, 03:38 PM   #4
mhicks
mhicks's Avatar
I think that all that switch on the aluminum cylinder does it prevent your compressor from kicking in if it is low on freon.
mhicks is offline   Reply With Quote
Old 10-11-2004, 10:46 PM   #5
Slonaker
Slonaker's Avatar
That switch on the dryer/receiver stops the compressor from turning if the pressure is too high or too low. Mine is new, replaced about 750 or 1000 miles ago.
Slonaker
Stock '01 Silverado
