I'd like to put modern 3pt retractable seat belts in my '67 GM. Anybody done this. Could the top part be bolted thrue the cab where the little plastic plug goes, high in the corners? would this be strong enough, or would it need to be re-inforced from behind? If I do it, I definatly want it all to work properly if there's ever a need! If you know what I mean?
The nut that is welded in the cab is made for a shoulder belt, so strength should not be a problem. I am in the process of installing three point belts out of an S-10 as others have done. It looks to be a fairly easy installation.
Jim |
Juliano's sells a kit to put it all together in the original places. The top bolt should be where the plug is.I went to a wrecker and found some that would fit.
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!! |
I have the set up from Chevy Duty. It works and was easy to install, but I'd have to say it really sucks as far as retracting on its own. The part on the right that slips into the shoulder buckle is very short..hate it. Would not buy again had I known.
Alex 1971 Lil' Red 350 SBC 700R4 |
Lovin' Life in Miss.!
I'd like to know more about the S-10 seat belts... What years? Did they fit in the factory 67-72 location on the floor beside the seat? I know I'm pushing it, but do any of em have blue interiors?
The truck... you hear that? No really, you did hear that?!!! |
If you get some seats out of the newer chev trucks[99-04]the belts are built into them.I have heard that they fit with very little work.lots of them are power seats to boot.You can even get them in leather.
Got Light Emitting Diode?
they will save your head from hitting the window in an accident too. a little more dough though
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
Yeah, I saw those.... they do look NICE. I allready shelled out the bones for the houndstooth upholstery.
67-72 Addict!
I just bought a set of retractable 2 point belts off ebay from a seller name FATRODDER. He also sells 3 point belts. I have not recieved them yet but will report in with the results after installing.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
I put some in a 67 i had I used 85 seat belts. YOu will have to drill a hole in the floor for the retractor and put a plate under it for strength Or make a bracket to go from the original retractor mounting location.
I have an 89 im stripping it looks like it would be better for a 72 because the retractor is more slender so you might look into that aswell. |
I had not thought of extending with a fabbed bracket!!!
#12 | |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#13 |
Blue primary with black. It Looks nice in the box!
#14 |
The LuvShack Garage
![]() 8 BALL THEME - CARRIED OVER FROM THE PO ![]()
#15 |
Thanks for all the hot tips! There's a bolt behind those plastic plugs!!!! BTW how do you get the plastic plugs out..? pull 'em, push 'em,, or screw 'em? so damn many options,, now I'm really confused
#16 |
Purple gas,
The plugs are just pressed in. Some will pull out easy, others will fight you to the end! Jim |
