I just put my 72 Blazer back together with a new motor and I am having some problems with the ignition wiring. It starts okay but when the key is back in the run position there isn't any power to the coil. I am not so sure about the wiring because I just bought the truck and they have added an HEI distributor and done a few other hack jobs on the wiring. I was wondering if anyone has any wiring schematics that might help me sort this out, Thanks
Chris ![]() |
The LuvShack Garage
CAN'T HELP YA, BUT SOMEONE ELSE WILL
WELCOME 2 THE BOARD FROM WEST TN. ![]() GREATEST (TRUCK BOARD ) PLACE ON EARTH ![]() DON'T FORGET 2 FILL OUT YOUR LOCATION UNDER THE "USER CP" IN TOP RIGHT CORNER
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
You need to run a new coil wire anyway if you added HEI. The stock wire is probably a resister wire. Run a ten gauge wire from the fuse block to the HEI distributor. On the right side of the fuse block you should see where you can use a female spade to hook to (Ignition unfused) terminal, Hope this helps
SKINNY TIRES RULE!
Here are the wiring diagrams a board member scanned and posted for all to use.
http://www.geocities.com/chevroletc1070/wiringdias.html
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Thanks for your help, I got it all straigthened out and runs good now
